Solved Installation fails with "Use of undefined constant KPATH_ADMIN"
13 years 3 weeks ago #147849 by Mi
I'm new to Kunena. However I expected the setup needs to just load the zip file.
However, after one hour trying to understand what's wrong, I had to give up.
So I downloaded pkg_kunena_v3.0.2_2013-08-18.zip and tried to add to my modules. Please note that I have Joomla 3.1.5 (latest version) WAMP SERVER 2.4 - 65bit (latest version) with Apache 2.4.4, PHP 5.4.12 and MySQL 5.6.12.
As soon and the package starts being uploaded on my server, I get a window with the follwoing error: Use of undefined constant KPATH_ADMIN - assumed 'KPATH_ADMIN' in C:\wamp\www\cristei26\administrator\components\com_kunena\install\schema.php on line 12.
The Whole (long) page follows.
Thanks in advance for any help
Mauro
Kunena Installation Failed!
Sorry, installation failed with following error:
( ! ) Notice: Use of undefined constant KPATH_ADMIN - assumed 'KPATH_ADMIN' in C:\wamp\www\cristei26\administrator\components\com_kunena\install\schema.php on line 12
Call Stack
# Time Memory Function Location
1 0.0003 266816 {main}( ) ..\index.php:0
2 0.0779 5398960 JAdministrator->dispatch( ) ..\index.php:56
3 0.0785 5451400 JComponentHelper::renderComponent( ) ..\application.php:166
4 0.0828 5510816 JComponentHelper::executeComponent( ) ..\helper.php:339
5 0.0830 5541456 require_once( 'C:\wamp\www\cristei26\administrator\components\com_kunena\kunena.php' ) ..\helper.php:359
6 0.0833 5551200 require_once( 'C:\wamp\www\cristei26\administrator\components\com_kunena\install.php' ) ..\kunena.php:19
7 0.0966 6972776 JControllerLegacy->execute( ) ..\install.php:33
8 0.0966 6972904 KunenaControllerInstall->run( ) ..\legacy.php:722
9 0.4757 8142688 KunenaControllerInstall->runStep( ) ..\controller.php:82
10 0.4757 8143184 call_user_func ( ) ..\controller.php:140
11 0.4757 8143184 KunenaModelInstall->stepDatabase( ) ..\controller.php:140
12 0.4757 8143184 KunenaModelInstall->installDatabase( ) ..\model.php:547
13 0.4773 8390960 require_once( 'C:\wamp\www\cristei26\administrator\components\com_kunena\install\schema.php' ) ..\model.php:661
( ! ) Notice: Use of undefined constant KPATH_ADMIN - assumed 'KPATH_ADMIN' in C:\wamp\www\cristei26\administrator\components\com_kunena\install\schema.php on line 13
Call Stack
( ! ) Warning: DOMDocument::load(): I/O warning : failed to load external entity "file:///C:/wamp/www/cristei26/administrator/KPATH_ADMIN/install/install.xml" in C:\wamp\www\cristei26\administrator\components\com_kunena\install\schema.php on line 206
Call Stack
13 0.4798 8388904 KunenaModelSchema->getCreateSQL( ) ..\model.php:663
14 0.4798 8389360 KunenaModelSchema->getDiffSchema( ) ..\schema.php:122
15 0.4798 8389664 KunenaModelSchema->getXmlSchema( ) ..\schema.php:95
16 0.4798 8389840 KunenaModelSchema->getSchemaFromFile( ) ..\schema.php:80
17 0.4798 8390480 load ( ) ..\schema.php:206
( ! ) Notice: Trying to get property of non-object in C:\wamp\www\cristei26\administrator\components\com_kunena\install\schema.php on line 281
Call Stack
15 0.4814 8409296 KunenaModelSchema->getSchemaDiff( ) ..\schema.php:101
( ! ) Warning: Invalid argument supplied for foreach() in C:\wamp\www\cristei26\administrator\components\com_kunena\install\schema.php on line 296
Call Stack
16 0.4824 8411240 KunenaModelSchema->listAllNodes( ) ..\schema.php:281
( ! ) Fatal error: Class 'KunenaRoute' not found in C:\wamp\www\cristei26\administrator\components\com_kunena\install\sql\install\php\sampledata.php on line 147
Call Stack
9 0.4933 8411280 KunenaControllerInstall->runStep( ) ..\controller.php:82
10 0.4933 8411776 call_user_func ( ) ..\controller.php:140
11 0.4934 8411776 KunenaModelInstall->stepDatabase( ) ..\controller.php:140
12 0.4934 8411776 KunenaModelInstall->installSampleData( ) ..\model.php:555
13 0.4942 8481912 installSampleData( ) ..\model.php:839
13 years 3 weeks ago #147883 by xillibit
Is it an upgrade or a clean install of Kunena ?
It seems that some Kunena classes aren't loaded correctly, check in your Joomla configuration that tmp and log paths are correct.
13 years 3 weeks ago - 13 years 3 weeks ago #147887 by sozzled
G'day, Mi, and welcome to Kunena.
Did use the installation method shown in the K 3.0 Installation Guide ?
Also please see Support for PC-hosted websites (e.g. WAMP, XAMPP) .
Last edit: 13 years 3 weeks ago by sozzled.
13 years 2 weeks ago #147979 by cbrace
I am seeing this error as well. I've tried both v3.0.0 as well as v3.0.2. Fresh install under Joomla v2.5.14.
Sorry, installation failed with following error: Notice: Use of undefined constant KPATH_ADMIN - assumed 'KPATH_ADMIN' in /usr/local/www/nuj/administrator/components/com_kunena/install/schema.php on line 12 Notice: Use of undefined constant KPATH_ADMIN - assumed 'KPATH_ADMIN' in /usr/local/www/nuj/administrator/components/com_kunena/install/schema.php on line 13 Notice: Trying to get property of non-object in /usr/local/www/nuj/administrator/components/com_kunena/install/schema.php on line 281 Warning: Invalid argument supplied for foreach() in /usr/local/www/nuj/administrator/components/com_kunena/install/schema.php on line 296 Fatal error: Class 'KunenaRoute' not found in /usr/local/www/nuj/administrator/components/com_kunena/install/sql/install/php/sampledata.php on line 147 Fatal error: Access to undeclared static property: JLoader::$classes in /usr/local/www/nuj/libraries/loader.php on line 195
13 years 2 weeks ago #147990 by xillibit
Check if check that System - Kunena Forum plugin has been turned on in your system. It's required to get Kunena to work.
Then when you have enabled it, go to Kunena backend the isntallation process will continue by itself.
12 years 11 months ago - 12 years 11 months ago #148716 by Prototyp 206
Hello, when i want to sort the categories, it doesn't save. [strike]And i also enabled SEF but links doesn't work and look like " teetown.de/en/ component/kunena/about-us"
I tried with several browsers.[/strike] Some idea anyone?
My config:
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 101M
Joomla default template details : gantry | author: RocketTheme, LLC | version: 4.1.12 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.2 | creationdate: 2013-08-18
Third-party components: Jomsocial 3.0.3
Plugins: JomSocial - My Kunena Forum Menu 3.0.3 | JomSocial - My Kunena Forum Posts 3.0.3 | JomSocial - Kunena Groups 3.0.3
Last edit: 12 years 11 months ago by sozzled. Reason: Topics merged; unrelated question struck out
