Please Read This First:
Do not use this category for:
Question 7.0.10 Deprecated issue
1 month 2 days ago - 1 month 2 days ago #235545 by Pinkeltje
Replied by Pinkeltje on topic 7.0.10 Deprecated issue
@David Li, please revert that change to KunenaUser.php.
#[\AllowDynamicProperties]
doesn’t fix anything, it only hides the notice. Since it’s a core file, it will be overwritten by the next update anyway.
And a deprecation notice doesn’t break Joomla; it’s only shown because error reporting is enabled.The fix is already in 7.0.11: go to Kunena → Tools → Setup socials and click it once. That removes the leftover icq column from your #__kunena_users table, which is the real cause of the notice.
If you still see notices after that, please post the exact message (property name) here.
Last edit: 1 month 2 days ago by Pinkeltje.
3 weeks 3 days ago #235603 by David Li
Replied by David Li on topic 7.0.10 Deprecated issue
No luck,
I installed latest 7.1.0 Clicked Fix Socials once.
Deprecated: Creation of dynamic property Kunena\Forum\Libraries\User\KunenaUser::$icq is deprecated in /var/www/html/libraries/kunena/src/User/KunenaUser.php on line 707
3 weeks 3 days ago - 3 weeks 3 days ago #235605 by Pinkeltje
After clicking Kunena → Tools → Setup socials, which message do you get? And please run this in phpMyAdmin and post the result:
SHOW COLUMNS FROM xxx_kunena_users LIKE 'icq';
If icq is still listed, please drop it manually (after a backup):
ALTER TABLE xxx_kunena_users DROP icq;
Then save a user in CB again and run the SHOW COLUMNS query once more. If icq is back, something else recreates it.
Last edit: 3 weeks 3 days ago by Pinkeltje.
3 weeks 3 days ago #235608 by David Li
In phpAdmin I see the icq column exists
After running Tools / Setup Socials:
Issues Detected In socials
Socials column are present
I manually deleted icq columne
I removed the workaround
Webpage loads correctly now.
So, I assume the Setup Socials isn't deleting the icq column.
thanx for your help!!!
3 weeks 3 days ago #235609 by Pinkeltje
I suppose that you forgot to click this button
3 weeks 3 days ago - 3 weeks 3 days ago #235610 by David Li
maybe...but that wasn't in the specific instructions :)
What would be nice is a little documentation on what this Setup Socials does / what its for.  Does it ONLY delete the icq column?  Or does it do more than that?
Thanx!
Last edit: 3 weeks 3 days ago by David Li.
