Please Read This First:
Do not use this category for:
Question 7.0.10 Deprecated issue
1 month 1 week ago - 1 month 1 week ago #235493 by David Li
Deprecated: Creation of dynamic property Kunena\Forum\Libraries\User\KunenaUser::$icq is deprecated in /var/www/html/libraries/kunena/src/User/KunenaUser.php on line 700
I was inadvertently on Beta 7.1 and then manually regressed to 7.0.10, but the above issue still exists when Saving a new user (in Community Builder FYI)
The Beta thread advises that this is fixed in later beta.  I assume it's a PHP 8.4 error?  Joomla latest 6.2.0
Thoughts to fix this?
Last edit: 1 month 1 week ago by David Li.
1 month 1 week ago #235494 by David Li
Replied by David Li on topic 7.0.10 Deprecated issue
As a test, I applied 7.1 RC on a test site. now:
Deprecated: Creation of dynamic property Kunena\Forum\Libraries\User\KunenaUser::$icq is deprecated in /var/www/html/libraries/kunena/src/User/KunenaUser.php on line 707
1 month 1 week ago - 1 month 9 hours ago #235501 by Pinkeltje
Replied by Pinkeltje on topic 7.0.10 Deprecated issue
The notice isn’t caused by Community Builder or PHP 8.4 itself.
KunenaUser::bind()
creates a property for every column in
#__kunena_users
 and your table still contains a leftover
icq
column. It should have been removed by the 6.4.0 upgrade step
remove_socials_columns
and the “Setup socials” tool doesn’t drop it either.Please make a backup, check the columns with
SHOW COLUMNS FROM xxx_kunena_users;
and drop it:
ALTER TABLE xxx_kunena_users DROP icq;
Also note: because you were on 7.1 beta and went back to 7.0.10, your database contains 7.1 columns e.g.
displayAgeBirthdate
On 7.0.10 those will trigger the same kind of notice. Either stay on 7.1 or remove those columns as well.
Last edit: 1 month 9 hours ago by Pinkeltje.
1 month 1 week ago #235502 by David Li
This makes sense because I think I was the one that reported the Setup Socials issue that the fix was then put into place. I'll test your recommendation and advise. Thanx for taking the time!
1 month 1 week ago #235503 by xillibit
Replied by xillibit on topic 7.0.10 Deprecated issue
I have made a change for Kunena 7.0.11 so if the column icq still exists it will be removed
1 month 1 week ago #235504 by David Li
Hi, 7.0.11 installed
same:
