Kunena 7.0.7 Released
Please Read This First:
Do not use this category for:
Solved Kunena mobile menu css issues
2 years 11 months ago #228815 by cjsmiff
Thank you, yes I am using a helix template. My 'System - Language Filter' is already off though. :-)
2 years 11 months ago #228817 by Leen
Replied by Leen on topic Kunena mobile menu css issues
a pity, I had hoped that this was also the cause for you.
and you also tested with My 'System - Language Filter on or off and cleaned joomla cache...
If you test it with the Cassiopeia - Default template does it work?
And the kunena template is also set as default ? sometimes it happens after Upgrade that the kunena template has to be saved as default again.
With kind regards
Leen
The following user(s) said Thank You: cjsmiff
2 years 11 months ago #228857 by rich
Replied by rich on topic Kunena mobile menu css issues
New users cannot post images or links. I have now reset this so that you can attach a picture.
2 years 10 months ago #228919 by cjsmiff
It's definitely a template conflict as it works fine with the Cassiopeia template. My screenshot attached, hopefully :-)
2 years 10 months ago - 2 years 10 months ago #228924 by rich
Please try the following code in the custom.css of Helix (see image), then possibly empty the cache. If this does not help, please post a link to your forum.
@media (max-width: 768px) {  #sp-main-body {     padding-top: 100px;   } }
Last edit: 2 years 10 months ago by rich.
2 years 10 months ago #228929 by cjsmiff
Thank you, I tried it but it didn't work.
I can't send a link as it's in a paid members area. Not to worry though, I have disabled the Kunena menu and nobody has complained, so i think it will be ok anyway.
Time to create page: 0.263 seconds
