Please Read This First:
Do not use this category for:
Solved Problems with Kunena using smartphone
8 years 8 months ago - 8 years 8 months ago #198594 by ita4012
WolfgangOWL wrote: I can confirm the behaviour if I click on the action button. But this is no Kunena issue. As I can see you don't use the standard Kunena template. You should contact the template developer to solve it.
I use Crypsis, as template. Is it not a Kunena.org template? Author link lets me think so.
Last edit: 8 years 8 months ago by ita4012.
8 years 8 months ago #198609 by WolfgangOWL
Crypsis is the default template of Kunena. I set 'show default actions' in the Crypsis basic settings to 'yes' on my website to test the issue and it works fine on my android smartphone. I think it may be a conflict with your Joomla template. Does everything work ok if you set 'show default actions' to 'no'?
The following user(s) said Thank You: ita4012
8 years 8 months ago #198615 by ita4012
Bingo! Everything works ok if I set 'show default actions' to 'no'.
Thanks for help
