Question Edit post relaces bbc tags with html tags
11 years 6 months ago #164916 by TheTub
J!3.4.1
Kunena 3.0.8
php 5.3.28
I posted up something in my board using
[b]some text[/b]
standard bbc for bold type and this worked as expected when posted.
But whenever I try to edit the post the tags are being replaced by html
<strong>some text</strong>
automatically.
Can someone point me in the direction of what I button I need to press to stop this happening?
11 years 6 months ago - 11 years 6 months ago #164922 by 810
for me it stays
[b] [/b]
I will try here again.
test text
Last edit: 11 years 6 months ago by 810.
11 years 6 months ago #164952 by TheTub
OK - so it works as expected for you which means we can probably solve this problem.
See images:
And after posting then selecting to edit:
11 years 6 months ago - 11 years 6 months ago #164953 by TheTub
Test - works fine on here but not on my site.
Last edit: 11 years 6 months ago by TheTub.
11 years 6 months ago #164956 by 810
maybe you have a plugin that's optimize the code
11 years 6 months ago #164984 by sozzled
I vaguely remember this happening, years ago, when people used the RokCandy plugin from Rockettheme in some of their old Joomla templates.
I thought that Rockettheme had either fixed this problem or they removed the plugin. This story may help: Some BBCodes replaced by HTML tags after editing message - caused by RokCandy
It may not be RokCandy causing the problem in this case. It may help to see your configuration report . It's possible that some Javascript optimiser is responsible (as 810 suggested) but it's difficult to know for sure.
Sounds like a Javascript library conflict to me.
