Question registration
11 years 6 months ago - 11 years 6 months ago #164486 by davem
registration was created by davem
Hopefully a simple question.
I need to stop anyone from registering when in the forum area. We have a great way built to allow new members and the Kunena section by-passes this.
I do want our real members to be able to register in Joomla, though.
I am a medium grade hacker of code, so simple is good.
With another componenet, it was a simple PHP file change. They did real good on that one.
Last edit: 11 years 6 months ago by davem. Reason: Used wrong description
11 years 6 months ago #164539 by 810
Replied by 810 on topic registration
we use joomla login.
So you can turn the default joomla registration off, then kunena is also turned off
11 years 6 months ago #164919 by davem
Replied by davem on topic registration
Sorry for the delay getting back here.
I had discovered the Joomla shut off of registration. I only want it to stop the registration by way of Kunena.
When I turn off for Joomla, No one can register anywhere and that gives undesired results.
Is there another solution with Kunena?
11 years 6 months ago #164920 by 810
11 years 6 months ago #164934 by sozzled
Replied by sozzled on topic registration
davem wrote: I only want it to stop the registration by way of Kunena.
When I turn off for Joomla, no-one can register anywhere and that gives undesired results.
The reply from 810 is basically correct. Kunena uses Joomla (or, perhaps, a Joomla extension you may have installed) for registering new accounts . You cannot disable account registration in Kunena but you can remove the link that people might use in Kunena if that is what you want to do.
We have discussed how to hide the registration link in this forum before.
I hope this extra information helps. :)
