Question Topic Icon / Boardcode Not Displaying Properly?
11 years 8 months ago #162912 by sozzled
WhenI said uninstall two plugins I meant uninstall the plugins. The two "JomSocial" plugins do not work at all with K 3.0. After you have done as I suggested, please post your configuration report again. Thank you
11 years 8 months ago - 11 years 8 months ago #162913 by sozzled
SCEM wrote: The images are exactly how they are appearing, blown up and oversized instead of being the actual size. So they are in this huge vertical strip. Does that make more sense?
Unfortunately I cannot see the problem just by looking at pictures. I need to see the actual web page. This means that I would need
a) the URL of your website; and
b) a test account to login.
Last edit: 11 years 8 months ago by sozzled.
11 years 8 months ago #162914 by SCEM
I was confused because I was not seeing "JomSocial" in the title?
So I wasn't sure if these are the two you were saying to uninstall.
I have uninstalled these...
My Forum Menu 2.0.3
Kunena Groups 2.0.3
Here is my updated Configuration Report:
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 90M | Max file upload: 82M
Joomla default template details : Fashion Life | author: JoomlaXTC | version: 2.0.1 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.7 | creationdate: 2015-02-01
Kunena version detailed: Kunena 3.0.7 | 2015-02-01 [ Galah ]
Plugins: None
Modules: Kunena Latest 3.0.1
11 years 8 months ago - 11 years 8 months ago #162915 by SCEM
Just start a new Topic here and you will see the issue.
URL: http://*********.com/index.php/forum/suggestion-box
Test Account:
Last edit: 11 years 8 months ago by SCEM. Reason: URL Removal
11 years 8 months ago - 11 years 8 months ago #162916 by sozzled
Replied by sozzled on topic Topic icons really big!
Thank you for that information.
I found the cause of your problem. The problem is caused by your Joomla site template CSS (as I mentioned earlier, see My Joomla site template makes a mess of Kunena ... )
I have the solution to fix this problem (and another layout issue I discovered on your site), if you are interested: see Solution for "Topic icons really big!" .
11 years 8 months ago #162917 by SCEM
Replied by SCEM on topic Topic icons really big!
@sozzled I truly appreciate you taking the time to help me with this issue but I was hoping to get an answer to this problem without have to pay for a solution. :(
Seems like such a simple fix that the right line of code inserted into the right file should fix it.
Unfortunately I am not a CSS expert which is why I came here seeking help.
Is there no one else here that could possible provide a solution to this issue for free?
I can't be the only one that has had to deal with this problem. Anyone?
I'm a graphic designer, perhaps I could create a cool graphic for whoever provides an answer. :woohoo:
Time to create page: 0.164 seconds
