Question Topic Icon / Boardcode Not Displaying Properly?
11 years 8 months ago - 11 years 8 months ago #162904 by SCEM
So when you start a new topic the icons you wish to choose to represent your post are bloated!
So your presented with a ugly vertical strip that you have to scroll down until reaching the topic area.
How can I fix this so the topic icon / barcode displays horizontally like it should be?
I have also attached 3 screenshots of what is happening. THANKS! ;)
Here Is My Configuration Report:
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 90M | Max file upload: 82M
Joomla default template details : Fashion Life | author: JoomlaXTC | version: 2.0.1 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.7 | creationdate: 2015-02-01
Kunena version detailed: Kunena 3.0.7 | 2015-02-01 [ Galah ]
Plugins: JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1
Last edit: 11 years 8 months ago by SCEM. Reason: Topic icon
11 years 8 months ago #162906 by sozzled
I am not sure that I completely understand what you mean by icons that appear bloated (like you have shown in your images), but I would like to make two suggestions:
1) I strongly suggest that you change your forum integration plugins as shown in red below:
Kunena - UddeIM Disabled
2) I strongly suggest that you uninstall the add-on plugins JomSocial - My Kunena Forum Menu 2.0.3 and JomSocial - Kunena Groups 2.0.3. These add-ons do not work with K 3.0.
I have a feeling that the problem you are having is caused by your Joomla site template CSS (see My Joomla site template makes a mess of Kunena ... . I think I have seen this problem once or twice before but I cannot remember exactly what was the cause.
First things first: make the changes I recommended and we will see what ideas we can come up with to address your problem.
11 years 8 months ago #162907 by SCEM
"1) I strongly suggest that you change your forum integration plugins as shown in red below:"
By change do you mean enable them?
"2) I strongly suggest that you uninstall the add-on plugins JomSocial - My Kunena Forum Menu 2.0.3 and JomSocial - Kunena Groups 2.0.3. These add-ons do not work with K 3.0."
I have never uninstalled plugins before could you walk me through this process please?
Sorry I'm such a noob, I just don't want to mess anything up. :ohmy:
11 years 8 months ago - 11 years 8 months ago #162908 by sozzled
By change do you mean enable them?:
I mean disable those plugins, show in red above
1) Go to Extensions » Extension Manager
2) Click Manage on the left side of the screen
3) Find the plugin JomSocial - My Kunena Forum Menu 2.0.3
4) Tick the checkbox next to this item and then click the Uninstall button at the top of the screen
5) Find the plugin JomSocial - Kunena Groups 2.0.3
6) Tick the checkbox next to this item and then click the Uninstall button at the top of the screen.
Last edit: 11 years 8 months ago by sozzled.
11 years 8 months ago - 11 years 8 months ago #162910 by SCEM
Ok I have the ones you suggested in red now disabled.
I can just ignore this part right, no changes here?
Now for the two you said two uninstall:
Im not seeing these or at least the JomSocial part in the title.
I did find these though:
My Forum Menu 2.0.3
Kunena Groups 2.0.3
Both were already disabled, are these the two you mean?
If so, should I still uninstall them, even if they were already disabled?
Last edit: 11 years 8 months ago by SCEM. Reason: Wrong plugin listed.
11 years 8 months ago - 11 years 8 months ago #162911 by SCEM
The images are exactly how they are appearing, blown up and oversized instead of being the actual size. So they are in this huge vertical strip. Does that make more sense?
Last edit: 11 years 8 months ago by SCEM. Reason: Typo
Time to create page: 0.166 seconds
