Question K 3.0.6 message preview not working
11 years 8 months ago #161881 by xillibit
What do-you see in firebug console or google chrome developper console ? You should see some javascript errors
11 years 8 months ago #161896 by dottwatson
No, only GoogleAds.
My site is www.wfrp.it/forum (now I've Garava template, but the behaviour is the same in Blue Eagle).
11 years 8 months ago #161897 by sozzled
The "Garava" template (designed for K 2.0) does not work with K 3.0 and will cause problems — see (for example) Cannot vote in polls - using [third-party] K 2.0 "Garava" template .
The problem with not being able to see the message preview is caused by a Javascript library conflict. There have been several discussion topics in this forum about the "message preview not working" and, in all cases, the problem was caused by a Javascript library conflict as the result of loading another Joomla extension that does not like to play nicely with Kunena.
11 years 8 months ago #161898 by dottwatson
Ok, thank you.
ASAP I check (I hope to found! :P ) the library that conflict against kunena ad I post in this topic.
11 years 8 months ago #161899 by dottwatson
Quick test.
I've disabled all the modules not html or menu and set Blue Eagle template and it doesn't work.
I'll inform you about news.
