Question K 3.0.6 message preview not working
11 years 9 months ago #161427 by dottwatson
Hi there,
if I click the preview button, nothing happens.
Here my configuration. Thank you for your help.
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 25M
Joomla default template details : a4joomla-stonewall-free | author: a4joomla.com | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Third-party components: UddeIM 3.2
Plugins: None
Modules: Kunena Latest 3.0.1
11 years 9 months ago #161431 by 810
ok, first try to change the joomla to prostar. and check if its working
11 years 9 months ago #161432 by dottwatson
ok, where?
Do you mean to install protostar template?
11 years 9 months ago #161433 by 810
backend - extenstion - template manager. Prostar should be there. That's the default joomla template.
11 years 9 months ago #161435 by dottwatson
In joomla 2.5 the default templates are:
•Beez 20 (Default template)
•Beez 5
•Atomic
I'm hope, I'm not wrong.
11 years 9 months ago #161436 by 810
ok, then use beeze 20.
You have removed some code on your config, so ii didn't know you are using j2.5
