Question K 3.0.6 message preview not working
- dottwatson
- Junior Member
I think the problem is that var e is null and the next if fails.
[e = document.id("kbbcode-preview"); read by mootools-core]
I check if I found a solution for this problem.
- dottwatson
- Junior Member
What do-you see in firebug console or google chrome developper console ? You should see some javascript errors
- dottwatson
- Junior Member
My site is www.wfrp.it/forum (now I've Garava template, but the behaviour is the same in Blue Eagle).
The problem with not being able to see the message preview is caused by a Javascript library conflict. There have been several discussion topics in this forum about the "message preview not working" and, in all cases, the problem was caused by a Javascript library conflict as the result of loading another Joomla extension that does not like to play nicely with Kunena.
- dottwatson
- Junior Member
ASAP I check (I hope to found!
