Question Any way to disable the timeout of green "NEW" identifier next to title of unread posts?
11 years 4 months ago #161350 by mimsy
Users are logging in to our forum and going about their day before reading all new posts. When they return, the system has timed out the "new" icon, making it difficult for them to identify unread posts. While using "Recent Topics" is a good way to locate unread posts, we would prefer to disable the timeout so the "NEW" identifiers disappear only after the post has been selected. Any advice?
11 years 4 months ago #161353 by sozzled
Unless you hack into the Kunena source code, I know of no other way to "disable" the timeout. This may not help but I suggest you read what has been written before on this subject: New indicator disappears
One of the developers may like to comment, perhaps.
11 years 4 months ago #161364 by 810
please add kunena report, there was a bug in > K3.0.2, we did fix it.
In K3.1 the time limit is set to keep it until 3 months.
11 years 4 months ago #161365 by sozzled
810 wrote: In K3.1 the time limit is set to keep it until 3 months.
K 3.1 does not exist and there is no way to test it, unfortunately, is there?
Time to create page: 0.332 seconds
