This is not a support forum for any of the products contained herein. For product support you should visit the developer's website.
The information given in this category is intended to guide users who want to use various third-party products with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of other Joomla extensions.
Question ARTIO JoomSEF: Link to individual posts not working
12 years 8 months ago - 12 years 8 months ago #147898 by mibert
Hi there,
I am running Kunena 3.0.2 on a Joomla 2.5.14 platform.
Additionally I am using a SEF URL component called ARTIO JoomSEF 4.4.3 with Kunena extension 3.0.10. SEF for Kunena is enabled.
My problem is, that the Links to individual posts in the forum is not working, when clicking on the forum post number in the upper right corner of each post ( #1 ) .
On my website, this link is converted to something like www.mywebsite.de/#12345 , which is pointing to the starting page of my site and not to the post.
I have also disabled SEF but the issue remains exactly the same, so I assume it is not an Artio problem.
Does anybody here have similar issues and how could you fix it?
Any advise will be most welcme.
With best regards
Michael
Last edit: 12 years 8 months ago by mibert.
12 years 8 months ago #147904 by xillibit
Can-you put here your Kunena report configuration settings ?
12 years 8 months ago - 12 years 8 months ago #147915 by sozzled
mibert wrote: I am using a SEF URL component called ARTIO JoomSEF 4.4.3 with Kunena extension 3.0.10.
As soon as I saw "ARTIO JoomSEF" I said to myself, "Haven't we received hundreds, maybe a thousand or more problems, from people who try to use ARTIO JoomSEF and didn't all of those problems disappear when people uninstall it.?"
The fact is that, as far as we know, ARTIO JoomSEF has not been compatible with Kunena since the days of K 1.7. ARTIO JoomSEF has caused more problems for Kunena than any other SEO/SEF product I can remember, I strongly suggest you look at Kunena Features in the Wiki.
For those who have problems using Kunena with ARTIO JoomSEF, you have four choices:
(1) Discuss your problems with the team that created and supports ARTIO JoomSEF;
(2) Turn off ARTIO JoomSEF for anything that relates to Kunena and accept that ARTIO JoomSEF just doesn't work with Kunena;
(3) Unistall ARTIO JoomSEF; or
(4) Uninstall Kunena ... if ARTIO JoomSEF is more important to you than it is to have a discussion forum on your website.
If, however the team that brought you ARTIO JoomSEF can give you a money-back assurance that their product works with K 3.0.2, then please let us know and we will amend the information in our Wiki.
Last edit: 12 years 8 months ago by sozzled.
12 years 8 months ago #148008 by mibert
Hi there,
as I mentioned, the problem persists, even after deactivating Artio.
Here is my configuration:
htaccess: Exists | PHP environment: Max execution time: 600 seconds | Max execution memory: 2600M | Max file upload: 64M
Joomla default template details : yoo_phoenix | author: YOOtheme | version: 5.5.13 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.2 | creationdate: 2013-08-18
Third-party components: CommunityBuilder 1.9 | UddeIM 3.1
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Search 3.0.1
Any advice would be most helpful.
Best regards
12 years 8 months ago #148011 by sozzled
Some people who have used ARTIO JoomSEF have reported problems with Kunena even after "deactivating" ARTIO JoomSEF. For example, see Kunena 1.5 latest links don't work after Artio JoomSEF 3 uninstall .
The point we need to make is that if people have used 3rd-party SEO/SEF extensions for Joomla (e.g ARTIO JoomSEF or sh404SEF) they may find themselves in trouble. The Kunena team does not recommend or endorse any 3rd-party SEO/SEF extensions for Joomla and the Kunena project is not affiliated or has any involvement with the developers of such products. The Kunena team recommends the use of native Joomla SEO .
This website here, at www.kunena.org , uses native Joomla SEO. Do you see any problems with the way that this website works, here, in relation to "links to invidual posts not working"?
12 years 8 months ago #148027 by mibert
Hi sozzled,
you may be right, but Artio is an important part of my site, so I do not want to ommit.
I have tried the following steps to identify Artio as a root cause:
- Disabled SEF for Kunena in Artio extension >> Still same effekt
- Uninstalled Artio >> Effect was gone.
- Activated Kunena own SEF function >> Working no problem.
I will get in touch with them to fix the issue.
Best regards and thanks again
Michael
Time to create page: 0.267 seconds
