Question No INSERT button with attachments
13 years 4 months ago - 13 years 4 months ago #146043 by sozzled
Thank you for your configuration report. We still cannot see the problem if we have no access to your forum to see the problem, at first hand, as you described it. Do you have a test account that we can use?
You can post details if this test account using the confidential tags, like this:
[confidential]Username: Password[/confidential]
You should also make your menu simpler. See Kunena menu issues for help with this.
Last edit: 13 years 4 months ago by sozzled.
13 years 4 months ago - 13 years 4 months ago #146050 by juice
Hello.
These are the access data for the text account:
As you can see, also message preview doesn't work.
Do the confidential informations can be viewed just by me and you?
Last edit: 13 years 4 months ago by juice.
13 years 4 months ago #146051 by sozzled
juice wrote: As you can see, also message preview doesn't work.
Ah! This is a vital clue! I already had suspicions that the missing or non-operative INSERT button was related to a Javascript issue but this information you have just given us confirms those suspicions. I do not need to login to your site to investigate further.
We must have received hundreds of questions about problems like this (see Before you post your question, read this first which contains a small selection of a few of those questions) and, even though you can see the BBcode toolbar editor (which is why xillibit asked you a question about this earlier in this topic) you have other issues that are also related to Javascript.
The cause of your problem is that you have another Joomla extension - a component, plugin, module or template (or something added by added by one of these things) that loads a Javascript function (or library of functions) that is incompatible with, conflicts with and clobbers Joomla's Mootools Javascript library.
Kunena needs Joomla's Mootols Javascript library to work. Remove the source of the Javascript conflict and the things that are "broken" will work for you.
juice wrote: Do the confidential informations can be viewed just by me and you?
The answer to that question is on the FAQs page (see the menu near the top of this page) in "Confidential information" - what does that mean?
The following user(s) said Thank You: juice
13 years 4 months ago #146054 by juice
After your answer I searched for mootools into my installation and I found that template I use asks to load mootools and it was setted to NO. I changed to YES and now all is working fine.
Thank you very much for your patience.
For the future I promise to visit the link you posted before to ask in the forum.
