- Thank you received: 3
Question After install site crashed
- cowboysdude
- Senior Member
sozzled wrote: I'm sure Matias can respond better than me but I'm going to make a speculative suggestion.
1) Make a copy of your entire site and use the copy as a test platform.
2) Trash and delete your Kunena menu (see Kunena Menu issues
3) The upgrade procedure, itself, appears to work successfully. The errors occur after you have completed the K 2.0.x -> K 3.0.0 upgrade.
4) Upgrade the various Kunena Add-ons that you have installed
5) Try with v 3.0.0 of the Blue Eagle template
6) Retain your test site and post your configuration report for the test site so that we might be able to better see the whole situation clearer.
This approach keeps your existing site unchanged and allows you to continue to operate. Obviously, if the above approach (steps 1-5) work then you might consider doing the same on your live production site. I hope this helps.
Did everything you suggested and still the same results... just crashes my site on the frontend...
- cowboysdude
- Senior Member
There has to be an answer to this...
Uncaught exception 'RuntimeException' with message 'Library path __DIR__ cannot be found.'
- cowboysdude
- Senior Member
Changing PHP from 4 to 5.3 help
People cannot run Joomla if they are still using PHP 4.mikr23 wrote: I had a similar problem.
