Question After install site crashed
13 years 6 months ago - 13 years 6 months ago #144084 by cowboysdude
I was running 2.04 and tried to upgrade to 3.0.... I did and it crashed... so I had to roll back to 2.04....
I do not have a report to send you but was wondering why and what would make it crash after an upgrade?
I'd be more then happy to try it again!
Is there anyone else with that issue?
Last edit: 13 years 6 months ago by cowboysdude.
13 years 6 months ago #144090 by 810
Replied by 810 on topic After install site crashed
Please enable kunena debug. And post here the error.
regards 810
13 years 6 months ago #144098 by Matias
Replied by Matias on topic After install site crashed
Can you also explain what exactly happened after the installation. Sometimes Joomla forgets to install some files or PHP uses the cached versions from them, so installing again may help.
13 years 6 months ago #144123 by cowboysdude
Ok going to try it again, will let you know! Thanks guys!
13 years 6 months ago - 13 years 6 months ago #144124 by cowboysdude
This is the error:
Fatal error: Uncaught exception 'RuntimeException' with message 'Library path __DIR__ cannot be found.' in /home/dallasco/public_html/libraries/loader.php:251 Stack trace: #0 /home/dallasco/public_html/libraries/kunena/bootstrap.php(19): JLoader::registerPrefix('Kunena', '__DIR__') #1 /home/dallasco/public_html/administrator/components/com_kunena/api.php(38): require_once('/home/dallasco/...') #2 /home/dallasco/public_html/plugins/system/kunena/kunena.php(28): require_once('/home/dallasco/...') #3 /home/dallasco/public_html/libraries/joomla/plugin/helper.php(194): plgSystemKunena->__construct(Object(JDispatcher), Array) #4 /home/dallasco/public_html/libraries/joomla/plugin/helper.php(125): JPluginHelper::_import(Object(stdClass), true, NULL) #5 /home/dallasco/public_html/libraries/joomla/application/application.php(229): JPluginHelper::importPlugin('system') #6 /home/dallasco/public_html/includes/application.php(116): JApplication->initialise(Array) #7 /home/dallasco/public_html/index.php(30): JSite->initialise() #8 {main in /home/dallasco/public_html/libraries/loader.php on line 251
Here is the report:
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 128M | Max file upload: 24M
Joomla default template details : yoo_vanilla | author: YOOtheme | version: 5.5.15 | creationdate: Unknown
Kunena default template details : Nova - Kunena 2.x | author: www.TemplateKunena.com | version: 1.0.1 | creationdate: 02.04.2013
Third-party components: UddeIM 3.0
Plugins: Search - Kunena Search 2.0.4 | Content - Kunena Discuss 2.0.4
Modules: Kunena Latest 2.0.4 | Kunena Stats 2.0.4 | Kunena Login 2.0.2 | Kunena Search 2.0.4
Any help would be appreciated! Now I gotta go do a roll back to get my site back up...
13 years 6 months ago - 13 years 1 week ago #144126 by sozzled
Replied by sozzled on topic After install site crashed
I'm sure Matias can respond better than me but I'm going to make a speculative suggestion.
1) Make a copy of your entire site and use the copy as a test platform.
2) Trash and delete your Kunena menu (see Kunena Menu issues
3) The upgrade procedure, itself, appears to work successfully. The errors occur after you have completed the K 2.0.x -> K 3.0.0 upgrade.
4) Upgrade the various Kunena Add-ons that you have installed
5) Try with v 3.0.0 of the Blue Eagle template
6) Retain your test site and post your configuration report for the test site so that we might be able to better see the whole situation clearer.
This approach keeps your existing site unchanged and allows you to continue to operate. Obviously, if the above approach (steps 1-5) work then you might consider doing the same on your live production site. I hope this helps. :)
Last edit: 13 years 1 week ago by sozzled.
The following user(s) said Thank You: cowboysdude
Time to create page: 0.154 seconds
