Solved Videos are not displayed in posts
11 years 3 months ago - 11 years 3 months ago #162251 by Enfield
Hi, I am using Kunena 3.0.6 in Joomla 3.3.6 When I add video in a post (using video button) it does not display in a post :unsure: Can you advise please?
My configuration report:
htaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Third-party components: CommunityBuilder 2.0.5 | UddeIM 3.5
Plugins: None
Last edit: 11 years 3 months ago by 810.
11 years 3 months ago #162252 by sozzled
Enfield wrote: When I add video in a post (using video button) it does not display in a post
This is a good question that deserves a serious and considered answer.
I am aware of two possible reasons why this issue may arise.
1) There was an issue in K 3.0.6 that was flagged two months ago (see Defect report: BBcode YouTube URL method Kunena 3.0.6 / J3.3.6 ) that affected the embedding of Youtube videos.
2) Regardless of the type of video (e.g. Youtube, Vimeo, Real Player, etc.) certain viewing platforms do not accommodate the embedded player within Kunena. As a demonstration of this, I invite you to look at the following example: www.kunena.org/forum/k-3-0-general-quest...-ban-users-in-kunena
When you view the example on a desktop or laptop you will see the embedded player. If you then look at the same topic on an iPad you will not see the embedded player. This is why, in order to help people watch the video, I used both the "video insert" tool as well as showing the URL link to the video.
I don't know if this helps you to understand what might be happening in your case but, certainly, it's a real issue and something that deserves more than a "one sentence" response.
11 years 3 months ago #162254 by 810
Please update to K3.0.7 and try again
The following user(s) said Thank You: Enfield
11 years 3 months ago #162255 by Enfield
Update to K3.0.7 solved that. Many thanks!
