Solved J! 3.x Beez3 template: Javascript (BBcode, emoticons and attachment) problems
i have well copy the file hide.js but the problem is the same.
i do not understand What templates are Mootools 1.2+ compliant or work normally and without ?the problem can be with mootools ?
my solution is desactivated the emoticon et the profil for the moment, but is not cool
if you want i can activated the debug mod or you send an account guest.
Best regard.
Arnaud.
For J! 3.2.3 the following templates work with Kunena without making any changes:Arnaud wrote: i do not understand What templates are Mootools 1.2+ compliant or work normally and without ?the problem can be with mootools?
1) Protostar
2) Beez20
The Beez3 template will work with Kunena but you need to make some changes to it.
- Thank you received: 2543
I be back to you with good news.
The problem has been now resolved.
the solutions are :
in first the modification of file hide.js with your fix
in second the modification this the file ../templates/beez3/javascript/md_stylechanger.js
on my template beez3, the font size function in Kunena is deactivated, for resolve this problem you need to modify this file on the line 61 with this script :
The problem is now resolved for the emoticon, bbcode and edit profil.
thank you very much. :woohoo:
