Solved J! 3.x Beez3 template: Javascript (BBcode, emoticons and attachment) problems
12 years 6 months ago #155124 by Arnaud
version joomla : 3.2.3
version kunena : 3.0.5
version explorer internet : 10
I have a few problems, i think of this is the same problem, maybe javascript, but in do not see and i need your help please.
bbcode : the bbcode bar do not display, the bbocode only display "charging bbcode"
emonticon : when i clic on the emoticon, there is never
file attachement : i cannot attache the file, the section is empty when i take a file.
i have disable few plug-gin for search the this problème but i do not see, i have activated the debug mod but i do not understand, i not webmaster.
can you help me please ? do you want an guest acccount ? my forum is an french forum, i have contacted the french support but i do not feed back.
on below the rapport configuration
thank you very much for your help
Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Missing | PHP environment: Max execution time: 300 seconds | Max execution memory: 512M | Max file upload: 64M
Joomla default template details : beez3 | author: Angie Radtke | version: 3.1.0 | creationdate: Unknown
Third-party components: UddeIM 3.2
Plugins: None
12 years 6 months ago #155128 by rich
Welcome Arnaud!
You are using the Joomla template beez3. This contains a bug. Please try this fix:
github.com/xillibit/joomla-cms/commit/62...cc37d1ee6f25e8a77357
12 years 6 months ago #155129 by Arnaud
Hi Rich,
thank you very much for your feed back speed
i try this fix and i back to you.
Arnaud
12 years 6 months ago #155135 by Arnaud
sorry, that do not work, can you check in attachment the file hide.js if i have no error ?
thank you verry much
12 years 6 months ago - 12 years 6 months ago #155137 by Arnaud
i back to you with any news, i well modified the file but do not work.
when i change the template with protostar, the problem is resolved but the display is not good with kunena.
when i change with beez 3 and Beez20, the problem is present.
do you have a idea ?
Last edit: 12 years 6 months ago by Arnaud.
12 years 6 months ago #155141 by rich
This solution should work. Are you sure that you did everything correctly? Try it with this file. And empty your cache after the change before you test.
Time to create page: 0.166 seconds
