Solved Private category shown to unregistered users
12 years 6 months ago - 12 years 4 months ago #155038 by edenoyer
I'm running Joomla 3.2.3 and Kunena 3.0.5.
I have created a "private" category with read rights only to a user group called "prestataires" and SuperUsers.
When somebody is logged in, the category is well displayed (I mean only to members of the selected groups) but the category is shown to every unregistred users ! How can I solve that ?
Thanks in advance for your help.
Emmanuel
Here is the config log :
Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Missing | PHP environment: Max execution time: 300 seconds | Max execution memory: 512M | Max file upload: 64M
Joomla default template details : neumann | author: | version: 1.0 | creationdate: Unknown
Plugins: None
Last edit: 12 years 4 months ago by edenoyer.
12 years 5 months ago #155282 by edenoyer
Does anybody have an idea to solve this problem?
Thanks in advance
Emmanuel
12 years 5 months ago - 12 years 5 months ago #155335 by sozzled
I think the reason that you have not received a reply is because we do not fully understand the exact problem that you seem to be having
edenoyer wrote: I have created a "private" category with read rights only to a user group called "prestataires" and SuperUsers.
If you are referring to a category called "Forums privés" on your site then I don't quite understand the problem. When I went to your website I could not see any topics in your "Forums privés" category, therefore what do you mean when you wrote
edenoyer wrote: ... the category is shown to every unregistered users ! How can I solve that ?
Well, I was unregistered and I could not see the topics in that category. Perhaps you mean a different category on your site? :dry:
Last edit: 12 years 5 months ago by sozzled.
12 years 5 months ago #155336 by edenoyer
Thank you for working on this topic.
Yes, the private part is "forum privés" and you couldn't see any topic in this section because there was no topic inside. I was waiting to be able to hide this complete section, including its title before posting.
I have created a "debug" topic and this topic is shown to unregistered users.
When I log in using a test account, this topic and the complete category are hidden.
12 years 5 months ago - 12 years 5 months ago #155362 by sozzled
edenoyer wrote: I have created a "debug" topic and this topic is shown to unregistered users. When I log in using a test account, this topic and the complete category are hidden.
It sounds like you know how to set up the category permissions to achieve the result you want.
edenoyer wrote: Yes, the private part is "forum privés" and you couldn't see any topic in this section because there was no topic inside.
Let me see if I understand you correctly. Are you saying that I could not see topics in your Forums privés category because there were are topics in that category or are you saying that I should not even be aware that you have a Forum privés category?
If you have a category where you created your "debug" topic and the "complete category" is hidden, why not use the same technique with your Forums privés category?
12 years 5 months ago #155368 by edenoyer
My problem is very simple :
The "forums privés" section and all its contents should not be displayed to unregistrered users.
You should not even be aware that the Forum privés section exists.
Only SuperUsers and "prestataires" group of users should see it.
Time to create page: 0.153 seconds
