Solved Can't insert image into post with the "Insert" button
11 years 2 months ago #168788 by 810
could you create a account on your site, so I can check whats wrong.
11 years 2 months ago #168789 by rich
I see on your image that no default template is selected.
11 years 2 months ago - 11 years 2 months ago #168793 by YonisHobby
810: I created the following account:
This is a direct link to create new topic: (As the forum is in Hebrew)
www.tissan.co.il/forum/מגדל-הפיקוח/topic/create
Rich: I tested both templates on a second server, the same behavior. Pressing any of the 3 buttons related to attachment will open the Windows Explorer window to look for a file to upload.
Can't insert or remove the file.
Once I added an attachment and submitted to the topic, I can edit the post and then can insert the attachment into the message.
Please notice that you can add attachment just can't insert them into the post in the first edit.
Last edit: 11 years 2 months ago by rich. Reason: Account made invisible for other users
11 years 2 months ago - 11 years 2 months ago #168795 by 810
try this:
Template manager
Select your template, select edit css.
select custom.css
Add this:
#Kunena .kfile-input { right:auto !important; }
Last edit: 11 years 2 months ago by 810.
The following user(s) said Thank You: YonisHobby
11 years 2 months ago #168844 by YonisHobby
Yes !!!
Finally it works. Thank you very much.
