Solved How to disable or remove "More Statistics"
12 years 11 months ago #151121 by Buda9
how to disable or remove "More statistics" => e.g. www.kunena.org/forum/statistics
12 years 11 months ago - 12 years 11 months ago #151122 by 9themestore
Hi Buda9,
If you want to disable the "More statistics" link, follow some bellow steps:
1. Login the your back-end of your site and go to "Components -> Kunena Forum -> Configurations".
2. Click the "Extra" tab and scroll mouse down.
3. Choose "No" with "Show Popular User Statistics" option and "Show Popular Subject Statistics" option.
4. Click Save button on the toolbar and back the front-end refresh your site.
Image:
Regards,
Last edit: 12 years 11 months ago by 9themestore.
The following user(s) said Thank You: Buda9
