Merged How to create category and sub-category icons in K 3.0
13 years 4 months ago - 13 years 4 months ago #145260 by sozzled
nickb wrote:
I want [to use] ../media/kunena/category_images/19_notlogin.png
You cannot use this in K 3.0.
If you read footnote #2 of Category icons you will see that the "feature" that displayed a different category icon when users are not logged-in to your forum (which was done by having a file called <cat_id>_notlogin.gif uploaded to the folder ../media/kunena/category_images), this feature was removed in K 2.0.
Therefore, the question of whether you can use a .PNG file instead of a .GIF file for this third [not logged-in] state is irrelevant.
In terms of the general question about using .PNG files instead of .GIF files for custom category icons, the information given in the Wiki article (and which I reproduced, in part, in my reply in msg #4 of this topic) is out of date and incorrect.
In a future version of Kunena we would like to allow users to upload either .PNG or .GIF files. Obviously, though, if you had two files, for example
only one of these files would actually be used.
As a temporary workaround, a simple way to use .PNG files instead of .GIF files is to look at the code in the file ../components/com_kunena/views/category/view.html.php between lines 156 and 164. The original source code is this:
// Check Unread Cat Images if (is_file ( JPATH_ROOT."/media/kunena/{$this->config->catimagepath}/{$category->id}_on.gif" )) { return "<img src=\"" . JUri::root(true) . "/media/kunena/{$this->config->catimagepath}/{$category->id}_on.gif\" border=\"0\" class='kforum-cat-image' alt=\" \" />"; } else { return $this->getIcon ( $this->ktemplate->categoryIcons[1], JText::_ ( 'COM_KUNENA_GEN_FORUM_NEWPOST' ) ); } } else { // Check Read Cat Images if (is_file ( JPATH_ROOT."/media/kunena/{$this->config->catimagepath}/{$category->id}_off.gif" )) { return "<img src=\"" . JUri::root(true) . "/media/kunena/{$this->config->catimagepath}/{$category->id}_off.gif\" border=\"0\" class='kforum-cat-image' alt=\" \" />";
You could simply change the ".gif" references to ".png" instead. However, here's another solution that may do the job easier for you:
===========This is untested and may result in your forum not functioning properly===========
(1) Download the attached file
File Attachment:
File Name: view.html.zip
File Size:4.86 KB
(2) Extract the file view.html.php to your personal hard drive.
(3) Using your favourite FTP program, rename the file ../components/com_kunena/views/category/view.html.php as ../components/com_kunena/views/category/view.html.old
(4) Using your favourite FTP program, copy the file you extracted in step (2) above to the folder ../components/com_kunena/views/category/
(5) This change will allow you to use any one (but only one) of the similarly named files:
In other words, if you have three files called 19_on.gif, 19_on.png and 19.jpg, the .GIF one will be used.
I hope this helps.
(Thanks to LittleJohn for providing me with the solution)
Last edit: 13 years 4 months ago by sozzled.
The following user(s) said Thank You: nickb
13 years 4 months ago #145273 by nickb
ok i will try it... i just wanna use only png because i dont like the Q of gif convert.
13 years 3 months ago #146210 by robinwave
This is nice. I will try it with my website too.
13 years 1 month ago - 13 years 1 month ago #148148 by YonisHobby
I'm using the latest version of Kunena installed on the latest version of Joomla.
I would like to have a different icon for every category. The solution I found is for early Kunena versions.
How do I implement it on the latest?
Many thanks!
Edit:
Placed it here by mistake. The solution found here:
Found the solution here:
www.kunena.org/docs/Category_icons
And this is my forum . :)
Last edit: 13 years 1 month ago by YonisHobby.
13 years 1 month ago #148151 by sozzled
*** Topics merged ***
You will find the answer to your question in this topic.
13 years 1 month ago #148209 by Ancientwolf
Read the "Change category icons". That changes all of them to an individual image, not what I'm looking for.
Already looked at the post in the 1.7 forums other have referred to before- it works on K2.0, but not 3.
www.kunena.org/forum/170-K-17-Templates-...ategory-icons#101195
Any way to do this once again? I'm surprised this still hasn't made it into the default setup.
