Solved Locking a category ...
13 years 5 months ago #145199 by Sparkybear
Hi all,
Am trying to get a new site setup with kunena 3. I think I might be having a problem... but maybe not....
Having created a category and then making it a "Locked" category, the category screen reports is as being a section. Is that what is supposed to happen, it never did that before in previous versions. ALso when it does that I cannot then go back into the category and make any choices as to polls, moderations etc.
I have attached some files to show what I mean.... "Forum1" shows the categories, as you can see with no locks.
"Forum2" shows that when I put a lock on "Site Announcements" it becomes a section.
"Forum3" shows that the "Site Announcements" in category view and shows that I can now only choose "Category Name and Description" and "Category Permissions".
"OldForum" shows what happened when you locked a category - ie it did NOT become a "section"
Can someone please help. I don't want to continue with the setup if I am doing something wrong OR their is a problem with my installation.
Thanks in advance
G
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 16M
Joomla default template details : rt_lumiere | author: RocketTheme, LLC | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.0 | creationdate: 2013-05-15
Plugins: None
13 years 5 months ago - 13 years 5 months ago #145206 by sozzled
Replied by sozzled on topic Locking a category ...
Sparkybear wrote: Having created a category and then making it a "Locked" category, the category screen reports is as being a section. Is that what is supposed to happen, it never did that before in previous versions.
As inconvenient as this may seem, this is actually how K 3.0 is designed to behave. Arguably, the design is not a perfect one, perhaps? ;)
This issue, and it's ramifications for moderating topics (that is, moving topics into a locked category that does not already have other topics in it), was discussed in Locked category ==> section . So, you see, this behaviour existed in a previous version of Kunena.
As far as other issues like "editing polls" are concerned, they are different and off-topic to this particular question.
Last edit: 13 years 5 months ago by sozzled.
The following user(s) said Thank You: Sparkybear
13 years 5 months ago #145212 by Sparkybear
Replied by Sparkybear on topic Locking a category ...
Thanks once again Sozzled......
I got my head round it now, thanks. I think it is one of those things that you could make it work any way and it wouldn't suit for another reason.
Anyway, I now know fully how to work around it which isn't that great a problem.
Brilliant as usual mate, thanks
Time to create page: 0.180 seconds
