Sticky Hide / disable login
12 years 5 months ago #156899 by sozzled
Replied by sozzled on topic Hide / disable login
*** Topics merged ***
G'day, GB1Kodiak, and welcome to the forum.
You will find the answer here in this topic.
12 years 5 months ago - 12 years 5 months ago #156900 by GB1Kodiak
Replied by GB1Kodiak on topic Hide / disable login
i tried this
www.kunena.org/docs/Disable_%28or_hide%29_the_login_form
but this isn't what i wanted.
i am trying to hide the profile area.
Last edit: 12 years 5 months ago by GB1Kodiak.
12 years 5 months ago #156901 by sozzled
You showed a picture with the login form highlighted. This area is called the profilebox. The information in Hide / disable login tells you what you need to do.
Do you understand better now? :dry:
12 years 5 months ago #156906 by GB1Kodiak
i added the code to my css file and still shows the profile box area when logged in. i purged browser and website cache too. still shows.
12 years 5 months ago #156923 by sozzled
I really don't know why the solution - which works for everyone else - does not work for you. Which file did you change?
In your first message you showed us a picture of the website here (at www.kunena.org ). Perhaps you have something completely different at your website? Perhaps you are not even using the K 3.0.5 Blue Eagle template? Perhaps you are not using K 3.0.5? Perhaps you did not store the changes where you should have stored the changes? Perhaps the CSS changes you made were overridden somewhere else? Did you look at a web design tool, like Firebug , to double check that the CSS changes were downloaded to your browser? I would check all these things.
12 years 5 months ago #156956 by nutter308
Replied by nutter308 on topic Hide / disable login
Make sure you have purged your cache through the joomla admin-cp, I do this first when making changes to my template.
