Kunena 7.0.8 Released
Merged K 3.0: How do I create announcements?
13 years 3 months ago - 13 years 3 months ago #144643 by Neokeyzer
And how can I make those available only on a specific category?
Thank you
This announcements: www.kunena.org/forum/announcement/list
NVM, got it... didnt see the Add New button
Last edit: 13 years 3 months ago by Neokeyzer.
13 years 2 months ago #145339 by Alacardjr
i was wondering the samething, how do you make a announcements or/and how to convert a post in to a announcement?
13 years 2 months ago #145340 by sozzled
Neokeyzer: The technique for making announcements in K 3.0 is the same as described in the topic K 2.0: How to make and edit announcements .
Alacardjr: To "convert" a post into an announcement, the easiest way go to the post and use the EDIT button, copy the BBCode (with CTRL-V), then use the announcement feature and paste (with CTRL-C) the text you copied and then save it. Should be fairly self-explanatory.
BTW, welcome to both of you to the forum. ;)
12 years 9 months ago #151301 by ManuelVoileux
site is voileux.org , Joomla 3.2, protostar, Kunena 303
How to setup moderator ID for creating, editing announcements ?
on the wiki I have read
> Simply turn on announcements in the Kunena backend >> Done
>and enter the Joomla User-IDs of the moderators or administrators, who are entitled to write announcements >> where ? which menu ? option ? users ? tools ?
I have set Global moderators that can moderate the forum, but I can't get through the announcement management?
Thanks for help.
Manuel
voileux.org
12 years 9 months ago - 12 years 9 months ago #151306 by rich
This option it was available in Kunena 1.5
It's modified since Kunena 1.6 (I think). If the option "Show Announcements" (in Kunena Configuration > Frontend) is enabled, admins and global moderators can create or edit announcements.
Last edit: 12 years 9 months ago by rich.
The following user(s) said Thank You: ManuelVoileux
12 years 9 months ago #151334 by ManuelVoileux
Many thanks for help. it works :) :) :)
Time to create page: 0.530 seconds
