Solved BBcode [img] do not display image
13 years 6 days ago #144598 by shorepower
Thx, I tried reinstalling 3.0.0 on top of the installation but that did not solve the problem. Will try the other options to see if I can isolate the problem.
One question. Would Kunena put other requirements on my host than SMF and phpBB for instance, both use an version of BBcode and both can display images using the img code.
Also, tried sending a private message with UddeIM and img worked with the message function.
Have in addition posted at JSN forum to see if someone knows about any errors.
13 years 6 days ago #144601 by sozzled
To answer your question about whether K 3.0 will operate on your hosted environment, I strongly suggest that you create a test site with a vanilla-flavoured version of J! 2.5.11 and K 3.0.0 (and nothing else) and see what happens. The problems that you are having may, indeed, be caused by whatever "stuff" is included with JSN, yes.
The following user(s) said Thank You: shorepower
13 years 6 days ago - 13 years 6 days ago #144618 by shorepower
I have reinstalled, starting from scratch, all the components, in the following order
Joomla 2.5.11
Kunena 3.0.0
UddeIM 1.6
Kunena Discuss
Kunena Search
JSN PowerAdmin
JSN Uniform
JSN Imageshow
JSN Air
The img attribute works and display the image correctly (did the installation stepwise and tested after each installed component) So the error must have happened in one of the upgrades or alternative during the migration from SMF.
As I'm migrating a medium sized forum with around 50K of posts I want to make sure that it works before and that a good plan on how to do the migration exists so what I want to test is to backup the data that I have now migrated from SMF to Kunena over to the clean installation described above.
Have searched the forum but can not find which MYSQL-tables for a Joomla 2.5.11 and Kunena 3.0.0 that I need to move to get users and data over to a fresh installation. Would that information be available anywhere
Thanks in advance and thanks for the support so far
Last edit: 13 years 6 days ago by shorepower.
13 years 4 days ago #144664 by shorepower
Anyone that have any information regarding this or can point me in the right direction?
Thx
13 years 3 days ago - 13 years 3 days ago #144678 by skybax
For joomla
(The prefix might be different on your installation)
User: table j25_users
Kunena: j25_kunena_messages
j25_kunena_messages_text
j25_kunena_categories
This are the core tables you need to move.
After migrating the tables go to
1 Kunena Component (backend)>> Tools >> Synchronize Users >> Select just Add user profiles to everyone
2 Kunena Component (backend)>> Tools >> Recount Statistics >> Select ALL
And see if everything works
Last edit: 13 years 3 days ago by skybax.
Time to create page: 0.517 seconds
