Question Button names not translated
13 years 6 months ago #144401 by Never-in-Doubt
rich wrote:
I have the latest version installed, how do I get this report please? If you tell me and stop pasting the same info that doesn't work for me, then I can do it for you. Your link relates to v.1.7 or something - I am using v.3/
You find it in "Dashboard > Tools"
Did that - installed the Welsh (which was the only one suitable, ie GB) language pack..... no change
You can install only languages which exist also in Joomla. But I think your complete Kunena installation is corrupted. Your system meets not the minimum conditions.
www.kunena.org/docs/K_3.0_Technical_Requirements
Maybe it helps if you try install Kunena via URL.
Thanks Rich - will try a fresh install now and report back :)
The topic has been locked.
13 years 6 months ago #144402 by Never-in-Doubt
sozzled wrote: Did you try to re-install Kunena (don't uninstall it, just install again, straight on top). Should take you 30 seconds. The procedure is fully explained in K 3.0 Upgrade Guide .
Hi Sozzled,
It works!!!
I did what you said and used the URL to upload the forum software, then went and did updates and after hitting refresh my forum now looks aye-ok!
Awesomeness - thank you :)
* As an aside the only error left at the moment is the lack of event when trying to save any profile edits. In the following URL (/forum/profile/edit/42-admin) when I click save it doesn't do anything - it's like an empty button.
Any idea's?
Happy to give you access if you think it'll help?
13 years 6 months ago #144404 by sozzled
Replied by sozzled on topic Button names not translated
Excellent news! Takes 30 seconds, doesn't it, and problem solved.
We'll close this discussion now and mark it as solved.
I'm still happy to talk with you (via Skype) if you want to contact me by email to discuss any other problems you may be having.
The following user(s) said Thank You: Never-in-Doubt
13 years 6 months ago #144415 by Never-in-Doubt
Thanks again, there is still one other error with saving profile...
I do appreciate your help here guys - and yes, took like 30 seconds :)
13 years 6 months ago #144419 by sozzled
The "other" problem is unrelated. I have offered you my personal assistance; it's your choice if you want it or not.
The "other" topic deserves it's own topic.
This topic is now formally closed.
