Question Button names not translated
13 years 6 months ago #144338 by sozzled
Replied by sozzled on topic Button names not translated
I am surprised that the symbolic literal strings are not translated to their correct English language names on your site. It could be a bad installation of K 3.0.0 and it may be advisable to re-install Kunena on your site. You can do that without affecting your existing forum configuration settings, categories that you may have created or forum topics that may have been posted.
Without seeing your configuration report, I am only guessing. We can continue to attempt to guess further as to the possible reasons why your site is misbehaving (as far as Kunena is concerned) or ...
Do you have some kind of HTML/Javascript code aggregation software running on your site (e.g. JCH_Optimizer) - again, this is just another wild guess.
The following user(s) said Thank You: Never-in-Doubt
The topic has been locked.
13 years 6 months ago #144353 by Never-in-Doubt
sozzled wrote: I am guessing that your forum is a non-English language forum and you have not installed the language pack for K 3.0.0, is that correct. Without your configuration report I don't have any other ideas. Sorry.
It's English - I am English - nothing non-english about the site or forum. I tried to load the language pack and it says "no files to upload" as per my last screen print that I posted.
13 years 6 months ago - 13 years 6 months ago #144354 by Never-in-Doubt
sozzled wrote: I am surprised that the symbolic literal strings are not translated to their correct English language names on your site. It could be a bad installation of K 3.0.0 and it may be advisable to re-install Kunena on your site. You can do that without affecting your existing forum configuration settings, categories that you may have created or forum topics that may have been posted.
But it's not just me now, someone else has just posted the same error....
Can you clarify, to reinstall do you mean just literally upload it again or do I have to do anything first to delete the current installation? Not 100% sure what you mean by reinstall it (new to this) thanks :)
sozzled wrote: Without seeing your configuration report, I am only guessing. We can continue to attempt to guess further as to the possible reasons why your site is misbehaving (as far as Kunena is concerned) or ...
I have the latest version installed, how do I get this report please? If you tell me and stop pasting the same info that doesn't work for me, then I can do it for you. Your link relates to v.1.7 or something - I am using v.3/
sozzled wrote: Do you have some kind of HTML/Javascript code aggregation software running on your site (e.g. JCH_Optimizer) - again, this is just another wild guess.
Nope, nothing like that - just a normal theme and normal extensions ;)
Last edit: 13 years 6 months ago by Never-in-Doubt.
13 years 6 months ago #144360 by Balázs
Check your Joomla warnings in Joomla Backend -> Extensions -> Extension Manager -> Warnings. Do you have small PHP file upload size?
13 years 6 months ago #144361 by Never-in-Doubt
Balázs wrote: Check your Joomla warnings in Joomla Backend -> Extensions -> Extension Manager -> Warnings. Do you have small PHP file upload size?
Thanks - it reads:
Your PHP memory limit is set below 8MB which may cause some issues when installing large extensions. Please set your memory limit to at least 16MB.
13 years 6 months ago - 13 years 6 months ago #144366 by Balázs
You should try this:
1. Download Kunena Language Package 3.0.0
2. Unzip.
3. Enter an extracted directory.
4. Choose your single language package (e.g. com_kunena_ar-AA_v3.0.0.zip) in a language directory.
5. Install this one in a Joomla Extension Manager.
Last edit: 13 years 6 months ago by Balázs.
