This category is for discussing issues with the K 3.0 Blue Eagle template.
Important Mobile Responsive Menu Problem w/ Kunena (Update: Not just mobile but desktop too!)
13 years 3 weeks ago #150304 by sozzled
The issue is not isolated just to what you see on a mobile phone display. It also happens on desktop displays, too. To be honest, I'm not sure if I know the reason why this occurs. :laugh:
13 years 2 weeks ago #150421 by cmantis
sozzled wrote: The issue is not isolated just to what you see on a mobile phone display. It also happens on desktop displays, too. To be honest, I'm not sure if I know the reason why this occurs. :laugh:
You know I just realized this and was coming back to post. It doesn't stick on the desktop menu either. That is why mobile menu is messed up. Usually when a menu item is selected the menu is highlighted and in my case has an arrow however (only) with Kunena it remains blank as if it wasn't even selected. Hope that gets sorted in an upcoming update.
13 years 1 week ago #150555 by Matias
It's not Kunena bug really. Its a limitation in menu module as it cannot associate alias into the real menu item.
Currently the only way to fix this issue is to move kunena menu items into your main menu and replace the alias in there.
The feature worked in Joomla 1.5, but somewhere between 1.5 and 2.5 Joomla broke it. The feature itself is rather easy to implement... Not sure why it's not in there anymore.
12 years 10 months ago #152480 by cmantis
Matias wrote: It's not Kunena bug really. Its a limitation in menu module as it cannot associate alias into the real menu item.
I am not sure that I follow. Are you suggesting I move the entire forum menu into my joomla main menu? Really I just want to get the 'Kunena' joomla main menu item to be highlighted like other main menu items when selected and display the proper name (in my case 'Forums') in the mobile menu.
12 years 10 months ago #152484 by coder4life
"I am not sure that I follow. Are you suggesting I move the entire forum menu into my joomla main menu?"
Correct that is what Matias is suggesting.
The problem occurs specifically because you are navigating in Kunena Menu. The Kunena Menu does not handle other menu visual controls of other menus. The best thing would to be compile Kunena Menus into the Site Menu so the site menu is responsible for handling visual aspects of the menu.
12 years 10 months ago - 12 years 10 months ago #152489 by Jiminimonka
Not sure if this is exactly the solution but, try this:
CREATE A NEW MENU, RATHER THAN EDITING YOUR EXISTING ONE FOR TESTING
In you Joomla backend, select your Main Menu.
Select the Kunena menu (on my site its called Forum)
Select the Menu Type option and choose Kunena Forum -> Home Page
Save & Close.
Your Forum page should be highlighted now when its the active page.
Please read the FAQ.
Only one question per topic.
Last edit: 12 years 10 months ago by Jiminimonka.
