This category is for discussing issues with the K 3.0 Blue Eagle template.
Question problem with dropdown button no showing
13 years 3 months ago #147015 by Jiminimonka
I don't know if this still holds true in the latest Gantry, but in the template manager, if there is an option Build Title Spans, disable that and see if it makes a difference. It used to cause lots of issues, but I think its gone from the newer versions (at least its gone from the new Rocket Theme templates).
Please read the FAQ.
Only one question per topic.
The following user(s) said Thank You: e654777
13 years 3 months ago #147017 by e654777
They took out build title spans. There is no more options to disable it. :)
13 years 3 months ago #147019 by Jiminimonka
Assuming you are not a member of Rockettheme, please post a support ticket at the Gantry support page - www.gantry-framework.org/support & groups.google.com/group/gantry-framework...omla-users/subscribe
I will see if someone on the team here can offer a solution, but it might take a while.
13 years 3 months ago #147021 by e654777
Yes, sir. I will do that. You have been very helpful. Thank you very much. :)
