This category is for discussing issues with the K 3.0 Blue Eagle template.
Question problem with dropdown button no showing
13 years 3 months ago - 13 years 3 months ago #146941 by e654777
I had this problem where dropdown button no showing. Please see attached image.
Any idea?
Many Thanks.
Edward
Last edit: 13 years 3 months ago by e654777.
13 years 3 months ago #146942 by Jiminimonka
Please refer to the top of this page and post your Configuration Report.
Please read the FAQ.
Only one question per topic.
13 years 3 months ago - 13 years 3 months ago #146943 by e654777
Is this what configuration report is? Hope this helps. :)
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 5M
Joomla default template details : gantry | author: RocketTheme, LLC | version: 4.1.12 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.1 | creationdate: 2013-06-29
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Plugins: None
13 years 3 months ago #146947 by Jiminimonka
At first glance it might be to do with your Gantry template. Could you check if you still get this issue if you use the default Joomla template?
13 years 3 months ago #146990 by e654777
Thanks for the reply.
Yes, apparently it was gantry standard template that is not showing the drop down correctly. Not sure how to change the css in gantry. Any idea how?
Thanks. :)
13 years 3 months ago #146997 by e654777
I read this forum and note that kunena does ave problem with gantry 4 template. is this true?
Thanks .. :)
Time to create page: 0.153 seconds
