Question [Help] uddeIM ... @@ **** !!!!
15 years 7 months ago #92023 by Sky_80
But there are other programs to send private messages to Kunena?
I upgraded from version 2.1.2 to 2.1.3 ueddIM
And now I can not read my new private messages.
I can SEND ... But when I clik on new messages ...
The BOX is empy. HELP ME!!
I'm Italy... My English is very bad. I use Google traslate. :lol:
15 years 7 months ago - 15 years 7 months ago #92026 by Mortti
First of all... this is not uddeIM Support forum, this is Kunena Support forum. Even though this particular partition is for uddeIM component problems individually, it not never... UddeIM problems in Kunena should be show for us?) Your photos will tell me only what joomla beginner can understand all of a sudden... in uddeIM?
uddeIM support forum you can find here: www.joomlapolis.com/forum/25-uddeim-plugin-and-component
Stephan Slabihoud(uddeIM developer)
is done also a very comprehensive FAQ, what you should read before/when using, when you use the that add-ons.
UddeIM is now in status 2.3 Stable but there is also some hotfix as you can see from the link which I sent there before.
<-- where those are?
Stephan homepage found here about uddeIM: www.slabihoud.de/software/id4001.htm
Stephan's private message system is most used solution in free softwares stage in Joomla!... I think you can also find the way to use it.
Last edit: 15 years 7 months ago by Mortti.
15 years 7 months ago #92047 by slabbi
There are several issues possible:
1. When your login module shows a new message it might be a bug in the module, so please contact the author (e.g. it might count the number of new messages in a wrong way).
2. After an upgrade of uddeIM when uddeIM does not show new messages even when you are sure that there is a new message available, you have not updated your database tables according to the README file enclosed with uddeIM.
Nevertheless you should get more familiar with the components you install. There is no version 2.1.2 of uddeIM, I am pretty sure that you are talking about Kunena 2.1.2 and 2.1.3 and about an unknown version of uddeIM.
Time to create page: 0.164 seconds
