Question Problem: Kunena + CB = JQuery + mootool.... too javascript
sozzled wrote: You seem to be the only person who has reported this issue. I've not encountered these issues before.
If you say that there's nothing in your Kunena configuration that can help us to help you, that's OK. I don't know how to help you get a quick answer without that information. You will have to wait until someone else has the same problems as you and can tell you what they did to fix the problems. Rest assured, if someone else asks the same questions as you did, we will be asking them for their K 1.6 configuration report, too.
Dear Sozzled, before to think that nobody reports this, you should think if they know....
My sites work fine. But is not good have site with enourmous javascript not necessary.
Kunena forum does not use anymore images-profile from community builder! So you can think don't care this issue. I understand!!!
But, if you try in all CB+kunena, happens what i said! In cb forum too.... Try to believe.
So is not my problem, but kunena or cb issue ... I presume
I continue to hope that will change, but i try to develope a new recall to keep in kunena avatar from cb without jquery . But i posted, becouse, I think that Matias, for example, is better than me in this..
astrogoal wrote: But, as i writed, I think that is the file "kunena.communitybuilder.php" of kunena that call jQuery from index of community builder...
That file was in Kunena 1.5 but isn't in Kunena 1.6. There's a problem with your installation. It's also possible that the file wasn't deleted in an update. It's not used by Kunena 1.6.
astrogoal wrote: Another question. Do you know how in this site, mootool is so small? In all my joomla sites is 80.000bytes...
Kunena 1.6 requires Joomla 1.5.20+ which uses MooTools 1.2 so Kunena does not load MooTools. If your MooTools is bigger or not minified, that also points to you having a 1.5 version, or you improperly updated from 1.5 to 1.6, or you have your core files hacked in some way that we can't support.
Thank you! But, have i delete this file? I don't think so. Phereps, does it required, if I would
downgrade to kunena 1.5, or I'm in wrong?
Ok, but i see a lot of kunena forum, for example alphaplug.com that has a very big mootool.
About mootool and kunena i read many posts, and your post of course, but is not clear for me:
Does kunena use mootool upgrade, from joomla /plugins/system/mtupgrade? I think so.
In this folder I have mootool (original, not hacked) of 115 kb (it is mootool 1.2.4..)
I see that many forum has this big mootool.js, but in this forum, if I look at the js file size, it reports different file size ONLY 33kb. Anyway, If I try to download from this forum your mootool it is of original size 115 file... this is a mistery for me!!
And what about the jquery library from community builder when in my kunena admin integration i set avatar from cb? Don't you think that is too javascript for who want avatar from cb? Or is required for example to resize the thumb image?
Thanks.
astrogoal wrote: Thank you! But, have i delete this file? I don't think so. Phereps, does it required, if I would
Yes, you can delete this file.
astrogoal wrote: Does kunena use mootool upgrade, from joomla /plugins/system/mtupgrade? I think so.
Attached is a screenshot of this forum showing the files that are included in Kunena when it loads (when a user is logged in, less when they aren't).
mediaboxAdv.js (for the lightbox)
default-min.js (a minified version of the basics needed for Kunena)
editor-min.js (a minified version of what's needed for the editor)
kunena-poll-min.js (a minified version of what's needed for polls)
Kunena also loads the follow Joomla core Javascript files:
joomla.javascript.js
calendar-setup.js
calendar.js
validate.js
mootools.js
The file size of the full MooTools framework is around 115k and Kunena uses what's built in.
astrogoal wrote: And what about the jquery library from community builder when in my kunena admin integration i set avatar from cb? Don't you think that is too javascript for who want avatar from cb? Or is required for example to resize the thumb image?
When CB integration is active in Kunena, CB loads jQuery. It gets cached by the browser the first time it's loaded so it's not reloaded fully on each page load. Some fields in CB need jQuery so it's out of our hands. We wish all Joomla developers would keep things simple and use the MooTools in the core instead of other JS frameworks.
Thank you. Now it is clear for me. I understand all.
Only I'm little sad, becouse i would use avatar from cb.. but and I will ask to cb developer for this issue...
