Question Problem: Kunena + CB = JQuery + mootool.... too javascript
So i have in my forum mootool (needed) and JQuery (not required!!)
But i would use avatar from community builder without this library not required for the forum!! I don't think that, for use an image, you have to recall, with this <script type="text/javascript" jquery...
I looked at the source code of my forum page and I haver this link to jquery library if i use community builder avatar!!!
Does exist a solution?
I have kunena cb and joomla last updated and i don't use kunena integration with cb plugin.
Have you read If you are having problems with K 1.6, please read this first ? Have you posted your question to our good friends at Joomlapolis as what was their advice?
sozzled wrote: What version Joomla? What version Kunena? What version Community Builder? Better still, why not post your K 1.6 configuration report?
I have all last updated version...
I also looked at community builder forum, that is in kunena, and discovered this
I can add that i'm studing this problem and i ask to community builder too
www.joomlapolis.com/forum/146-general/15...uery--mootool#159248
But, as i writed, I think that is the file "kunena.communitybuilder.php" of kunena that call jQuery from index of community builder...
Another question. Do you know how in this site, mootool is so small? In all my joomla sites is 80.000bytes...
THANKS
sozzled wrote: I'm sorry but "I have all the latest versions" does not answer my questions. I need to know the version numbers. Do you know how to post your K 1.6 configuration report?
Dear Sozzled, after speak with you long time ago, i use only all version, joomla 1.22, kunena 1.6.3, and cb 1.4 of course....
I don't thing depend by my configuration, it is simply a kunena file that call a community builder file that load jquery, even if is not required. That's all. For example, i said that also community builder forum has this "issue" (I think that to load a not necessary library is a real issue!!!)
Phereps Matias or others and you can think somemthing for next kunena release...
ps: are you from aries? Or gemini? Now we are at +1 time zone (5 a.m) it's very late, good night!
If you say that there's nothing in your Kunena configuration that can help us to help you, that's OK. I don't know how to help you get a quick answer without that information. You will have to wait until someone else has the same problems as you and can tell you what they did to fix the problems. Rest assured, if someone else asks the same questions as you did, we will be asking them for their K 1.6 configuration report, too.
