Question Avatar Problem
15 years 10 months ago #80194 by Ruhrpottjung
Avatar Problem was created by Ruhrpottjung
I installed yesterday Kunena into Joomla, so far so good.
Now I saw that there is not possibility to upload avatars. Can someone tell me what I did wrong?
Here also the Support File:
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 256M | Max file upload: 20M
Joomla default template details : ja_purity | author: JoomlArt.com | version: 1.2.0 | creationdate: 12/26/07
Kunena default template details : Example Template | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Third-party components: AlphaUserPoints: Installed (Version : 1.5.12) | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.2)
Modules: Kunena Latest: Disabled or not installed | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.2)
So it would be nice if someone can help me with that issue.
Greetings
Hans
15 years 10 months ago #80204 by Mortti
Replied by Mortti on topic Re: Avatar Problem
Which avatar and profile you have there activated... what Kunena use now?
Look integration tab in configuration and select what you want use, maybe that can help?
At the moment they are "Auto Detect" but you have also AUP installed there...
integration_avatar auto
integration_profile auto
The following user(s) said Thank You: Ruhrpottjung
15 years 10 months ago #80207 by xillibit
Replied by xillibit on topic Re: Avatar Problem
I advise you to disable legacy mode, if it's possible.
I think your problem is you can access to kunena profile, because you have AUP installed, so it's integrated automatically. So, in kunena configuration panel, in tab integration choose for profile kunena.
15 years 10 months ago #80210 by Ruhrpottjung
Replied by Ruhrpottjung on topic Re: Avatar Problem
the legacy is not able to disable because it's needed.
But Mortti was right with the settings into integration.
When I set it to Kunena everything works perfect!
Thank you so much for the fast and perfect help.
Greetings
Hans
15 years 10 months ago #80250 by sozzled
Replied by sozzled on topic Re: Avatar Problem
Ruhrpottjung wrote: the legacy is not able to disable because it's needed.
Needed? Needed by what?
Please read the very important information about Legacy mode in the Wiki. Please read what I wrote a couple of days ago in Joomla legacy mode and Kunena .
We may disagree but let me be clear on one important point: in my work I do not "need" any software that is is not supported by its manufacturer especially if that old, unsupported software prevents me caring for my users in the future. In the world of webcraft we need to keep up-to-date with technology because we don't know what lies around the corner.
Changes in the way that web browsers work (particularly the software that's developed by Microsoft) often pay little regard to today's "standards" in the push to gain larger market share by exploiting new features and new standards. There are no guarantees that tomorrow's web standards will be compatible with today's standards and woe to those who remain locked in the past.
I'm pleased that the problem discussed in this topic was fixed. I would not be acting responsibly, however, if I totally ignored the very real issues associated with Joomla "legacy mode".
15 years 10 months ago #80251 by Ruhrpottjung
Needed by UDDEIM. When I have a look at the plugin, Joomla told me that it run only in legacy mode.
Greetings
Hans
Time to create page: 0.152 seconds
