Question JomSocial and Kunena Karma Integration
However (and this is a personal preference), I believe that the link to my Forum Settings page is more appropriately placed under the Profile dropdown. This method is also much simpler to apply manually.
Edit file **/components/com_community/libraries/toolbar.php
change:
to:
yes, essentially you are just adding another part, but I find it more clear to tell people to change than to add
yaksushi, sorry I couldn't do this for you immediately, but as I'm sure you understand I must meet supporters requests first
This is now available in version 2.3 of my JomSocial and Kunena Profile Integration
Maker of:
Both are available at my website.
I'll be putting something under your Christmas tree for tomorrow morning. Promise not to look and make sure you leave me a bottle of Guinness on the mantle. I have a bottle opener.
Neocold wrote:
Azure wrote: Well done, Neocold! Great solution!
As you're probably aware after your direct intervention with bedding your other excellent hack in for me, I have changed the Kunena Karma to an 'applaud' system, completely disabling negative karma so that only positive feedback can be given to a poster. I am using Jomsocial to display member profiles but because of the craziness of operating two different karma systems, switched the JS one off.
Could your hack be tweaked to display my 'applaud' (positive karma) count on the JS profile page without having to set up the JS karma system? Further, would it be feasible to be able to include Kunena 'thank you's' received and given on the Jomsocial profile page?
Cheers,
Azure
Azure, your request has been completed and applied to your website, if you have any questions or requests about it feel free to PM or email me.
"Do or do not, there is no try..."
Thanks for all your great work! Wasn't a fortune but I did drop a little in your stocking. Merry Christmas!
Congratulations you have found a Kunena bug! Hehe, this is not brought on by my hack but the simple solution is to go to **/components/com_kunena/template/default/view/profile.horizontal.php and replace:
with:
It would appear that when the karma was added someone forgot to add it to the horizontal as they did the vertical profile display.
Maker of:
