Important REINSTALL KUNENA NOT WORKED - URGENT
17 years 7 months ago #12007 by Lintzy
the latest Kunena Version? 1.5.0 or 1.0.9? 1.5.0 is alpha, you should install 1.0.9, this is stable.
17 years 7 months ago #12009 by david.murphy
Just tried it and this is what i get...
Your Extension appears to be written for an older version of Joomla!. You must enable the System - Legacy Plugin in the Plugin Manager if you wish to complete this task.
17 years 7 months ago - 17 years 7 months ago #12011 by Lintzy
then do this, switch it to legacy mode. KN 1.0.9 only works in legacy mode.
Last edit: 17 years 7 months ago by Lintzy.
17 years 7 months ago - 17 years 7 months ago #12012 by sozzled
Ahhh ... a picture's worth a thousand words! The problem has nothing to do with the version of Kunena (even though david.murphy hasn't supplied the version information we requested). (Although I we're probably discussing K 1.0.9 ... the "latest" version.)
The problem is that david.muruphy has fiddled with the default Kunena parameters. Read docs.kunena.com/index.php/Configuration . Change "Use Joomla Style?" = no
Last edit: 17 years 7 months ago by sozzled.
17 years 7 months ago #12014 by Lintzy
No, i guess, he first installed 1.5.0, which works native, but is an alpha version with bugs. After that he installed 1.0.9 and got this report to switch to legacy.
17 years 7 months ago #12121 by david.murphy
Thanks, I reinstalled everything from scratch.. and it works fine now. apart from!
When im go on Kunena Administration TO ADD NEW Main Forum and Sub Forum it redirects me to Kunena Control Panel, then when i click the back button it goes back. so i cant create any sub forums within Main Forum
