Important REINSTALL KUNENA NOT WORKED - URGENT
17 years 7 months ago #11989 by david.murphy
I recently did an update on my site and it completely messed Kunena up... so i unistalled kunena and deleted the files out of the FTP. but now when i try to install it again the old categories show but when i click on the home part it comes up html text and doesnt load or work... how can i completly re-do kunena without having to reinstall joomla!?!?
David
17 years 7 months ago - 17 years 7 months ago #11991 by moof
Do you have access to the database? If so delete all the lines that start jos_fb, (drop) fb is the prefix for kunena (ex fireboard). that will remove your forum from the DB, then overwrite your files for good measure and re-install.
Last edit: 17 years 7 months ago by moof.
17 years 7 months ago - 17 years 7 months ago #11992 by core2
Do you have backup you can restore to? Did you follow the instruction in docs.kunena.com/index.php/Upgrade_Instructions ? And did that discover this problem on your test site? With upgrade, do you refer to Joomla or Kunena or other component, and which version (from and to)?
Any error messages?
Normally using the uninstalling tool within Joomla would remove the file associated with a component, so it shouldn't be necessary to remove files manually.
Did you have content in your forum or do want to drop the content and make a clean install? If that what you want you must go into your database and remove all tables containing _fb_ in their names. But before you do this you MUST backup your hole database, there doesn't exist a undo in database! And you must be very careful altering database manually and understand what you are doing.
Visit the Kunena documantation .
Last edit: 17 years 7 months ago by core2.
17 years 7 months ago - 17 years 7 months ago #11993 by sozzled
We will try to work through your problem with you if you are patient and can help us.
When you say you attempted to "update on [your] site" what did you update? Please tell us what version of Kunena and Joomla you are now using.
I don't understand what you mean by "when i click on the home part it comes up html text and doesnt load or work". The home part of what? Perhaps the easiest way to demonstrate your problem is to provide us with a screenshot that illustrates the problem, or the URL of your website.
Waiting for further information from you. Stay cool. :cheer:
Last edit: 17 years 7 months ago by sozzled.
17 years 7 months ago #11995 by grumblemarc
Agreed. My question also is-what kind of update did you do to your site that you had to attempt to install Kunena? Attempting to repair Kunena would be meaningless if your site is compromised.
17 years 7 months ago #12006 by david.murphy
I Completly reinstalled Joomla and downloaded the Latest Kunena and Installed it and when it has done the same thing...
Image attached
