Question SEF Problem with search results
17 years 8 months ago - 17 years 8 months ago #4705 by fungkur
this bug is already solved, but since fireboard 1.04, this fix still is not included inside the source code
Solution here
so i convert the fixes for Kunena 1.08
Fix
../lib/kunena.search.class.php
change this
Line 267
<a href="' . sefRelToAbs(KUNENA_LIVEURLREL . '&amp;func=view&amp;id=' . $result->id . '&amp;catid=' . $result->catid . '#' . $result->id) . '" >
to
<a href="'. sefRelToAbs(KUNENA_LIVEURLREL . '&func=view&id=' . $result->id . '&catid=' . $result->catid). '#' . $result->id . '" >
this will fix the URL for example
../component/option,com_kunena/Itemid,64/catid,87/#21280&func=view&id=21280
to
../component/option,com_kunena/Itemid,64/catid,87/func,view/id,21280/#21280
*hope developer will include this fixes for the next version
Last edit: 17 years 8 months ago by fungkur.
17 years 8 months ago #4712 by spacereactor
can't find kunena.search.class.php with the following coding
17 years 8 months ago #4716 by fungkur
around line 267-268. (kunena v1.0.8 and not v1.0.7)
to be more specific u can try this
Line 268
change to
17 years 8 months ago #4761 by Matias
Fixed for 1.0.9
17 years 8 months ago #4863 by fungkur
Matias wrote:
Fixed for 1.0.9
thanks Matias!
