Question Some Bugs and problems!
17 years 7 months ago - 17 years 7 months ago #1342 by forum-migrations
Problem #1: [FIXED IN 1.0.8]
slashes
Problem #2: [FOR ANONYMOUS USERS]
Redundancy on Database tables:
Why fireboard needs the mail on each message??
jos_fb_messages
id parent thread catid name userid email
1 0 1 13 Felipe 64 [email protected]
2 0 2 13 Felipe 64 [email protected]
Problem #3: [FIXED IN 1.0.8]
Why my mail is showed like 3 times when im watching a post??
source code:
<input type = "hidden" name = "email" size = "35" class = "inputbox" maxlength = "35" value = " [email protected] "/>
Problem #4 [FIXED IN 1.0.8]
Why fireboard show numbers above messages on subcategories??
Code of fb_sub_category_list.php:
if ($lastPosttime != 0)
unset($obj_lp);
$database->setQuery("SELECT id, thread, catid,name, subject, userid from #__fb_messages WHERE time=$lastPosttime and hold='0' and moved!='1' LIMIT 1" ;
$database->loadObject($obj_lp);
$latestname = $obj_lp->name;
$latestcatid = $obj_lp->catid;
$latestid = $obj_lp->id;
$latestsubject = stripslashes($obj_lp->subject);
$latestuserid = $obj_lp->userid;
$latestthread = $obj_lp->thread;
// count messages in thread
$database->setQuery("SELECT count(id) from #__fb_messages WHERE thread=$latestthread AND hold=0";
$latestcount = $database->loadResult();
$latestpage = ceil($latestcount / $fbConfig->messages_per_page);
echo($latestpage); // HERE!!!!!!!!!!! WHY????
Problem #5:
Why Fireboard redirect to homepage when login??
Problem #6: (this is not a real bug) [CLICK IMAGE IN 1.0.8]
Why Fireboard do image attachments like this??
[im g size=511]myimage.jpg[/img]
Resized, but sometimes look ugly or bad, and you cant view the full image
What i had to do?
[u rl="http:\myimage.jpg"][ im g size=100]myimage.jpg[/img][/url]
Example of a thumbnail with link to full image
Problem #7 (related with slashes): [FIXED IN 1.0.8]
testing under windows, attachment was added (image) and the table:
jos_fb_attachment table
mesid filelocation
36501 C:AppServwwwjom/media/kunena/attachments/legacy/images/before.jpg
where are the \?
attachment table working for view referer post on administrator but replace with dummy doesnt work here (just img erased without replacement)
And[/b
Bonus problem:
hehe, while posting, i saw that tags size and bold arent working, without end tag, maybe this help to have right tags, but.............
Problem #8:
HTML Entities:
The html entities will be coded again on msg function, then, a &quot; will be showed like &amp;quote;.
But........ what about if i store the character on the database i mean '&' or '"', then the metatag will be closed before the end, and will be above of the page.
Problem #9: (don't know if is solved on kunena)
Empty search:
The variable that contains the search, isn't declared when you advance from the first search page to other.
Then ill have a empty search, i was reading the code, i could solve that with some modifications on joomla files., the content of variable is not passed to functions of pagination.
Searching in google i found a lot of sites with that problem.
Problem #10:
soon...
Last edit: 17 years 7 months ago by Matias.
Time to create page: 0.224 seconds
