Use this category:
Question Multiple problems after update to 6.1.3
3 years 3 months ago #228887 by webenhanced
Sorry I forgot to add that I created a bunch of categories before trying to delete one of them.
3 years 3 months ago #228888 by webenhanced
I have done a fresh joomla 4.3.3 installation and installed Kunena 6.1.3. The sample data is installed.
I installed into the root directory instead of the /portal/ directory I was using previously. I also turned off php output buffering (which is on the other site I have been playing with.
I tried to delete a category (Suggestion Box) and still get the error message "View not found [name, type, prefix]: categories, html, site".
Here is the server log from that same time:
AH01071: Got error 'PHP message: PHP Warning: Undefined property: Kunena\\Forum\\Administrator\\View\\Categories\\HtmlView::$list in /var/www/vhosts/myplacegympie.org/testing.myplacegympie.org/administrator/components/com_kunena/tmpl/categories/default.php on line 107PHP message: PHP Warning: Attempt to read property "Direction" on null in /var/www/vhosts/myplacegympie.org/testing.myplacegympie.org/administrator/components/com_kunena/tmpl/categories/default.php on line 107PHP message: PHP Warning: Undefined property: Kunena\\Forum\\Administrator\\View\\Categories\\HtmlView::$list in /var/www/vhosts/myplacegympie.org/testing.myplacegympie.org/administrator/components/com_kunena/tmpl/categories/default.php on line 115PHP message: PHP Warning: Attempt to read property "Ordering" on null in /var/www/vhosts/myplacegympie.org/testing.myplacegympie.org/administrator/components/com_kunena/tmpl/categories/default.php on line 115', referer: testing.myplacegympie.org/administrator/...nena&view=categories
Server is running PHP 8.1.22 in FPM on Apache. It is using the same settings as the ones posted in the original post above.
3 years 3 months ago #228889 by webenhanced
I am using Firefox browser with add blocker and JS blocker turned off. I have also tried using a open source Chromium browser with the same error message.
3 years 3 months ago #228890 by webenhanced
I just installed the language pack, just in case, and that made no difference to this issue.
