Use this category:
Question Dutch language and functions of Aurelia template
3 years 4 months ago #228676 by rich
I have installed the Kunena DEV 6.1.3 and language pack and find
  1. English has not been translated
  2. I have various settings in the template changed to 'No' icons in  boxes still appear and can be used
  3. I have selected the SCeditor
  4. what code for LESS is available to avoid that BBcode blocks are shown but none of them is wanted and is ticked out in the template settings. I am running a website where all text - options should be kept simple.
These settings do not work for the CKEditor. For the CKEditor you need to create a customckeditor_config.js and remove the icons. docs.kunena.org/en/faq/ckeditor-configuration
The following user(s) said Thank You: HanKortekaas
3 years 4 months ago - 3 years 4 months ago #228684 by HanKortekaas
Last edit: 3 years 4 months ago by HanKortekaas.
3 years 4 months ago - 3 years 4 months ago #228685 by HanKortekaas
see attachment
Han
Last edit: 3 years 4 months ago by HanKortekaas. Reason: used the same image name
3 years 4 months ago #228686 by xillibit
Do-you have errors in your javascript console of your browser ?
The translation for ckeditor it's detailled here www.kunena.org/docs/en/faq/ckeditor-configuration , you need to put the translation file of the language of your choice in /media/kunena/core/js/lang, then you need to set this language in the ckeditor configuration
3 years 4 months ago #228691 by HanKortekaas
I do not have any javascript error.
What I tried is to change'on line 1138  'a.ui.addButton("Source"'  into 'a.ui.addButton("Bron"  and when I found that it did not translate I copied back the file by FTP .
Then the button had no 'Source' nor 'Bron'.  Characterset is still UT-8 -BOM
I will follow your hint on the translation.
Han
3 years 4 months ago - 3 years 4 months ago #228692 by xillibit
You shouldn't touch the ckeditor.js file, all the language files for ckeditor4 are here : github.com/ckeditor/ckeditor4/tree/master/lang only the english one is inclued into packages. Then follow the doc : www.kunena.org/docs/en/faq/ckeditor-configuration
Last edit: 3 years 4 months ago by xillibit.
