Use this category:
Question Dutch language and functions of Aurelia template
- HanKortekaas
- Premium Member
- familiewapen
- English has not been translated
- I have various settings in the template changed to 'No' icons in boxes still appear and can be used
- I have selected the SCeditor
- what code for LESS is available to avoid that BBcode blocks are shown but none of them is wanted and is ticked out in the template settings. I am running a website where all text - options should be kept simple.
Han
. but with CK editor I can turn off certain things.
With kind regards
Leen
Hello,I have installed the Kunena DEV 6.1.3 and language pack and find
So if i understand it right, all these points are related to sceditor ? There is already an issue opened for it github : github.com/Kunena/Kunena-Forum/issues/8532
- HanKortekaas
- Premium Member
- familiewapen
Is work still in proces or has it stopped because of lack of developers.?
Han
- HanKortekaas
- Premium Member
- familiewapen
I have to start looking for another template and make a decission to use Aurelia instead of failures.
Thanks for the info.
New question: if i'm not mistaken there was an item in the downloads for paid templates. Has this been removed??
Han
