Use this category:
Solved Error by Installation
4 years 3 months ago #223867 by naderfrd
Hello.
I tried to download the package for the first time but failed. for the second time the below errors are displayed.
I tried to Uninstall the package and install it again, but some packages are not removed
Now I can't uninstall or reinstall the package:
JInstaller: :Install: Error SQL Duplicate entry 'com_' for key 'PRIMARY'
Extension installation aborted.
Package Install: There was an error installing an extension: com_kunena_
Joomla Version: 4.1.5
Download source :
I also tried to download and install it through Joomla admin panel> Extensions: Install> Install from web> Kunena, but it still gives an error
Could you please help me to fix this issue? Thanks.
4 years 3 months ago #223868 by Leen
Replied by Leen on topic Error by Installation
Same question here, see if this works for youd in this topic
www.kunena.org/forum/k-6-0-support/16466...ate-entry-com#222401
With kind regards
Leen
4 years 3 months ago - 4 years 3 months ago #223875 by naderfrd
Replied by naderfrd on topic Error by Installation
I found and fixed it. Thank you
Last edit: 4 years 3 months ago by naderfrd.
