Use this category:
Solved Kunena 5.2.5 has failed!
5 years 4 months ago #218063 by ernestortiz
Wow! It works! Thanks!
5 years 4 months ago #218064 by ernestortiz
I know this is another subject, but maybe it is related with the installation problem. Please, note on  democraciaparticipativa.net/foro/statistics.html that the name of people are gone. I tested it on some kunena templates.
The console throw these errors:
- Uncaught SyntaxError: Unexpected token '?' - a7163f8….js:1
- Uncaught ReferenceError: jQuery is not defined at statistics.html:89
and
- Uncaught SyntaxError: Unexpected token '<' at statistics.html:129
5 years 4 months ago #218071 by xillibit
Replied by xillibit on topic Kunena 5.2.5 has failed!
The javascript error is related to an issue into the file democraciaparticipativa.net/cache/gk/d21...190531d6316425530.js , it's related to gk not Kunena
The others errors is because jQuery isn't loaded in the page
5 years 4 months ago #218078 by rich
Replied by rich on topic Kunena 5.2.5 has failed!
It seems, the gk is an optimize tool, because it loads all scripts from /cache/gk. Exclude Kunena from this tool.
5 years 4 months ago #218101 by ernestortiz
Hi. At the end I installed a brand new Kunena on my localhost; and once I see it was working well, I visited folder by folder on the server, erase kunena files and upload the new ones from my localhost (except the media folder) to the server. That solved the whole situation. Just in case someone need it, these are the files (attached).
The following user(s) said Thank You: fabea1907
