Use this category:
Solved Kunena 5.2.5 has failed!
5 years 4 months ago - 5 years 4 months ago #218007 by ernestortiz
After updating to Kunena 5.2.5, I get this message from Kunena 5.2.5 Installer: "Installation of Kunena 5.2.5 has failed!". And shows no other details than "Preparing installation" (NOTE: my Joomla & Kunena language is Spanish, so, messages could differ a bit from real English installation process).
I'm working with the latest Joomla 3.9.27. There is no cache.
I have access to the server and tested a lot of things without success.
Any help will be appreciated. Thanks in advance.
Last edit: 5 years 4 months ago by ernestortiz.
5 years 4 months ago #218008 by rich
Replied by rich on topic Kunena 5.2.5 has failed!
Please go to /administrator/logs and tell us the content of the com_kunena.log.php
5 years 4 months ago #218025 by ernestortiz
Thanks. I'm sorry, but there is no kunena log at all.
5 years 4 months ago #218040 by rich
The com_kunena.log.php is an own file and should be in the folder logs. There is no php file with this name?
5 years 4 months ago #218042 by ernestortiz
No, there is not. I will install Kunena in a brand new Joomla site on my localhost and (if have success) I will copy/overwrite each Kunena file to the server. Because I do not know what else to do...
5 years 4 months ago #218045 by rich
Which version is installed currently?
I'm not sure if it helps, but try the following:
Start the installation again and when the installation stopped, go to \administrator\components\com_kunena and remove the install.php
Then refresh in the backend the page.
If it does not help, enable the Joomla debug mode and set Error Reporting to Development. Maybe you get a more precise error message.
