- Thank you received: 1
Use this category:
Solved updating from 5.2.2 to 5.2.3 said missing openssl
- micheldu42
- Junior Member
Thank you once again for your help.
I have duly found the install.script.php file on my local site directory C:\wamp\www\sitejoomla\administrator\components\com_kunena\install
On the line 54 the script wa already :
protected $extensions = array('dom', 'gd', 'json', 'pcre', 'SimpleXML', )'
mbstring was not mentionned, shall I add it ?
On the other hand , I don'tfind where is the file changes.md ?
Could you tell me more ?
Open the zip of Kunena pkg_kunena_v5.2.3_2021-03-07.zip with 7-zip by example, then go into packages then go into com_kunena_5.2.3.zip then go into install. Open there the install.script.php and modify like in my link above. Save it and update the zip package when asked. Then under Joomla! install this package
The file changes.md is here : github.com/Kunena/Kunena-Forum/blob/5.2.3/CHANGES.md
- micheldu42
- Junior Member
I have followed all your detailed steps and I have been succesfull when updating kunena from 5.2.2 to 5.2.3 on my local site.
Otherwise I do not understand what to do with your :
- micheldu42
- Junior Member
And if necessary how ?
