Use this category:
Question Upgrade from Kunena 1.7.2
My specific question is this: Can I upgrade from Kunena 1.7.2 directly to the 5.0.14 version you referenced in my Joomla 2.5 website before I upgrade Joomla to 3.5.1? I did not think that Kunena 5.X was compatible with Joomla 2.5.28. If it is, that would be great.
I really appreciate your help - this is quite new to me.
Charles
- Thank you received: 2544
Yes, you can install Kunena 5.0.14 on Joomla 2.5 before you upgrade to Joomla 3.5.1. Afterwards, when Joomla is up to date then install also the current Kunena version. Thats in principle all.My specific question is this: Can I upgrade from Kunena 1.7.2 directly to the 5.0.14 version you referenced in my Joomla 2.5 website before I upgrade Joomla to 3.5.1? I did not think that Kunena 5.X was compatible with Joomla 2.5.28. If it is, that would be great.
Thank you again for staying with me. I had a failure installing the 5.0.14 package. So I tried a more step-by-step approach and installed first 3.0.8 and then 4.0.11 successfully. Then I tried 5.0.14 again, but got the same error:
"Joomla! 2.5.28 is not supported. Minimum required version is Joomla! 3.5.1, but it is highly recommended to use Joomla! 3.6.2 or later.
Package Install: Custom install routine failure"
To me, this implies that 5.0.14 is not compatible with Joomla 2.5.28. Maybe you have a suggestion.
Is it possible to do another method: export the Kunena database table and then import that to the Joomla 3 site with a fresh install of Kunena 5.1.10
Appreciate your help
-Charles
why don't you update Joomla after updatig to Kunena 4.0.11 successfully? Joomla 2.5.x is outdated. The current Version is 3.9.5.
Sebi
But a upgrade from K 4.0.11 to K5.1.10 should also works.
On further checking, the Kunena 4.0.11 is functional but does have some formatting issues, e.g. little black squares in the menu tabs.
I will take your advice, however, and upgrade Joomla next once I get my other extensions squared away.
I finally realized how to better understand using GitHub to see the release details. The key being to click on the little ticket icon to open the details window. It says there that Kunena 4.0.11 requires Joomla 3.4 or higher. I must be lucky to have it functioning on my Joomla 2.5 system. With this knowledge, I hope my future questions will be more intelligent.
- Charles
